Tuxmask75
Just learning FF
Is there any way to do Seamless Tiling for only the image component when doing an offset?( so that the image is not mirrored)I don't want to do an overall override for the full filter since there are components that don't work with the Seamless Tiling checkbox.
Oh dear good question. There used to be something in regard to it but I don't remember.
Try
Create a color control and enable "Allow Images" then you'll see the color slot become some image. On the side you'll see a little triangle, hit that, and go to "placement". There should be a part called "tiling" change that to your liking.
28 unregistered users.
