Majority
Posts: 6 |
Hello, I'm new to Filter Forge wizardry
and I'm trying to make a simple texture seamless pattern (worm like pattern)to use as a high map and normal map, but I cant' make this simple shape on filter forge, can you guys help me? here the texture I made on Photoshop: ![]() Alcino Major |
| Posted: May 2, 2014 7:11 am | ||
Majority
Posts: 6 |
Anyone? Please?
| Posted: May 6, 2014 9:19 am | ||
Hmm.. getting that specific shape is probably a bit more difficult, but getting close to it would be a matter of figuring out how to deal with each noise pattern.
Likewise, this texture will be kinda technical to accomplish in FilterForge, but I'm pretty sure its doable. Will give it a shot but there might be sometime of wait. |
| Posted: May 7, 2014 3:13 am | ||
Majority
Posts: 6 |
Thanks Skybase, doesn't need to be that specific shape, as you can see it's only a random worm shape pattern.
it's amazing how a simple organic shape be so complex to reproduce on the filter forge I'm curious to see your results again thanks for accepting this challenge Alcino Major |
| Posted: May 7, 2014 9:30 am | ||
I mean if you discount the fact that each line isn't touching, it's not that bad.
First create a simple base shape (the worm) and then feed that into the bomber - adjust the rest of the parameters on the bomber. The example image just showed each object not touching each other which basically (at this point) isn't exactly possible in FilterForge. It's one of those topics that trouble us. But I'm sure we can get pretty clever with it. |
| Posted: May 7, 2014 7:23 pm | ||
Majority
Posts: 6 |
well I have never used filter forge before, I'm a 3d modeler designer, and I'm using Unreal Engine 4 custom shaders to make procedural textures, I am trying to make this shape on external tools like filter forge, Genetica and Substance Designer with no success
This texture is actually for a very complex material: aluminum with a worm like micro/detail texture pattern + macro textures variations I will share the material (shader) with you when I finish it also I will post here some pics of the final results. I will appreciate your help! Thanks again Alcino Major |
| Posted: May 7, 2014 9:52 pm | ||
xirja
UberZev's Stones filter was a good starting point for me to come up with these:
http://www.filterforge.com/upload/for...67701f128e http://www.filterforge.com/upload/for...2b692a31f2 _____________________________________________________
| Posted: May 10, 2014 10:10 am | ||
Majority
Posts: 6 |
Nice finding xirja, there's some similarities on that filters
thanks! Alcino Major |
| Posted: May 10, 2014 10:49 am | ||
Majority
Posts: 6 |
I think I am a complete noob
even with the help of these similar filters: http://www.filterforge.com/upload/for...67701f128e I cannot make the lines not touching each other ![]() Alcino Major |
| Posted: May 12, 2014 6:30 am | ||
