This filter :
Filter link
....is very very slow. What do you suggest to make it faster without losing image quality? |
| Posted: April 24, 2014 2:19 pm | ||
Well using blurs and the motion blurs do come at a cost of filter speed....If those are critical to the image output then not much to do.....There are some tips around that might help you in speeding it up a bit..But with all those blurs I don't know that it will help to much...
Here is a method from ThreeDee to improve speed a bit on blurs... http://www.filterforge.com/forum/read...sage125710 Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: April 27, 2014 10:14 am | ||
Yes, you are right.
The blurs are used to create a different feeling between different parts inside the filter. As you can see in the second and in the fourth circle, I use the blurs to create smooth and reflecting surfaces. |
| Posted: April 27, 2014 11:34 am | ||
266 unregistered users.
