untalmau
materials and textures 3d
hi.
i am new on filter forge.
but i just need to save the normal map ( bumpmap ) on each filter i create.
i download some filters forge to create a normal map
but I need the original normal map created on every filter.
can i download ( save only the normal map ) ?
thanks so much
www.worldanatomy.com
MKBreuer
MKBreuer
Filters: 47
1. you need FF Professionell
2. the filter must be a surface filter with a height
3. all existing: go to Filter > Render Maps > Normal Map
4. got to File > save image as...
that is all smile;)
Just simple, but not simpler. (A.E)
14 unregistered users.
