Filters: 711
I have a request for ThreeDee.
If I remember well, somewhere in the forum, you wrote that you have some filter with a very large number of settings or composed of many smaller filters combined together.
I like your filters very much and I would be very interested to see any filters that you didn't upload. No matter if they are messy or very complex, I would like to try them. smile;)
It would be interesting also for the other filters makers, I think.
Hi Ramlyn,
Well, that doesn't really narrow it down very much... I can think of about 25 filters that might fit into that category.
Wild guess: Image Montage?
Filters: 711
Very nice! smile;)
You made me very curious to see also the other 24. Ha! Ha!
I guess I could put a random filter trick here on this thread.
Particle depth tricks: fake cast shadows
Since actual cast shadows are hopelessly slow, you can use fake shadows to add depth to Bomber particles when the particles "float in space."
Actually, a couple of different things have been used here to add depth:
1) Depth sorting with a perlin noise input
2) Scaling with same perlin run through a tone curve for better distribution (if you use the perlin as is, you get too many large particles)
3) Making "shadow" particles and compositing them between other particles.
Here's the filter.
Bomber depth.ffxml
A bit more complex version:
It's pretty subtle, but you can see the difference when there are no shadows:
Filters: 711
Very interesting! And the difference between the two previous is very clear. Without shadows, all the spheres appear just as a copy of the same one. Instead, adding the shadows, they get deepness and 3D feeling.
Thank you for sharing the "Bomber depth". I'll surely use it.
266 unregistered users.
