First of all... great editor... I'm loving it.
I'm trying to find a way to limit a slider to a minimum value... is that possible? I've seen that IntSlider has a maximum value.
gr...
Ron
Yes, that is possible and can be done via Remappers. Here's how:
1. Select the Slider component you want to limit (must be connected)
2. In its properties, check "Use Remappers" -- you'll see the Remapper
3. Select the Remapper
4. In its properties, set the Minimum slider to desired value
Here's the pic:
