Hello, I want to ask if there could be possible to put links to other already available filters in the library inside the about tab of a filter that is going to be submitted to the library
The reason for doing this is that if you may be making 2 or 3 different alternative filters with the same topic you could put them in the about tab so the user knows about them.
I have tested it myself and it does not work when this is done on a custom filter, as the link is only plain text and is not recognized as a link, BUT maybe when submitted to the library this link inside the about tab could be recognized and converted to a link, I do not know.
In the about tab there is already the main link to that filter, so I thought that maybe you could put another link to another filter
Maybe this is not possible to do to avoid spam, but would be silly to put spam there, as the filter is going through a test from the FF team then any link that is not to a filter forge filter would be deleted
Sorry, this won't happen. Feel free to include links as plain text.
Thanks for your answer
I already thought that the answer would be no, but wanted to ask it anyway, as probably it was already possible and I did not know about it.
Does not matter if it will not be possible, I can always put the links to the filters on the comments page of that filter and put a note in the about tab
23 unregistered users.
