Hello, I have seen that if you have built a filter (or any filter you may have or downloaded) and after finishing it and ordered all the controls, you go to the Result component and change the "Simple filter" to "Surface" then it gets disconnected from all the other components, but this is NOT a great problem as you can just simply connect again the components, THE GREATEST AND MOST WORST COLLATERAL effect this action has is that it will DESTROY AND SCRAMBLE ALL THE CONTROLS LIST YOU HAVE ALREADY CAREFULLY ORDERED!!!!! smile:cry:
Please, WHY changing "Simple Filter" to "Surface" DESTROYS order of controls?
This would not be a problem if you have only a few of controls settings but if you have more than 20, or more than 50, or as it happens in my Alphabet Texture Creator extended you have 99 controls components?
It will take a whole lot of time to rebuild again all the controls list you had carefully done and created BEFORE changing from simple filter to surface smile:( smile:cry:
If you are building the filter from scratch and you know about this you can preview this by switching this at the beginning, but what if you have already built the filter and then want to try an alternative version using the "surface" result?
WHY is done this way and can´t keep the same order of controls?
Could be done something about this topic to make it better?
This is by design: unlinking the component subtree from Result will reset the order to the default state.
Yes, the order of controls should be restored via Ctrl+Z but at the moment its state is not saved. Restoring via Ctrl+Z will be supported in a future update.
If this is by the design, I think that the desings could be improved
I have to say that I am NOT unlinking the component subtree myself from Result, I am ONLY switching from "Simple filter" to "Surface", but it seems that changing this settings automatically disconnects the components, and also happens the same in the other way.
I have seen that this happens the same also with Bomber component when activating HDR MODE, ALL the components that could be linked are disconnected also destroying all the filter.
OH! Good news that this can be solved, fixed and improved in some way, and this would be a good idea, and good way to restore them.
Thanks
GMM 23 December 2013
Please, is there any posible news about this topic?
I think this is a very important thing, and something really bad that does not let you freely test and experiment with filter making, at least with already made filters you may have made with many organized settings
Would really love that this could be available and son be fixed with this Ctrl+Z you have told
Hope and wish that you can give some good news about this
Thanks for your help
This has been fixed and will be available in the next update 4.010.
WOW!!! Thanks very much for this very good news, and happy that this very bad thing has been finally solved and will be available in next update whenevet this may happen
Spokenrivers
Filters: 58
I use XML notepad to copy the control order before I make the change, then after the change reopen the file and paste back in the copy you have made. smile:)
adz
I use this to sort alphabetically ... its ugly!! but it works. You will need to understand VBS
Call RunFunctions
Sub RunFunctions
Dim va_array2()
if 1=1 then
vs_file = "C:\Users\Adam Law\AppData\Roaming\Filter Forge 3\My Filters\AJLDilateColourToAlpha.ffxml"
vs_filetext = ReadTextFile(vs_file)
'WScript.Echo("File: " & vs_1)
else
vs_file = Wscript.Arguments(0)
end If
va_array1 =GFMatchArray(vs_filetext, "<[^<]*<[^<]*value\-en[^>]*>", true ,true ,true)
ReDim va_array2(2, UBound(va_array1))
For count=1 To ubound (va_array1)
va_array2(0,count)=count
vs_1="id\='[^']*'"
vs_1=Replace(vs_1,"'", Chr(34))
va_array2(1,count)= GFMatch(va_array1(count), vs_1, true, true, true)
va_array2(2,count)= GFMatch(va_array1(count), "value\-en[^>]*", true, true, true)
Next
vs_1 = GFMatch(vs_filetext, "<ControlsOrder>[\S\s]*<\/ControlsOrder>", true, true, true)
va_array3 = TransposeDim(va_array2)
Call sortarray(va_array3, 2)
va_array3 = TransposeDim(va_array3)
vs_replace= "<ControlsOrder>"+ vbnewline
vs_replace= vs_replace+ "<Automatic value='false'/>" + vbnewline
vs_replace = Replace(vs_replace,"'", Chr(34))
vs_replace= vs_replace+ ""+ vbnewline
vs_replace= vs_replace+ "<Item " + va_array3(1,count) + " order=" + Chr(34) +CStr(count)+Chr(34) +"/>" + vbnewline
Next
" + vbNewLine
vs_replace= vs_replace+ "</ControlsOrder>"
vs_filetext = Replace(vs_filetext, vs_1, vs_replace)
Call WriteTextFile(vs_file +"",vs_filetext)
If 1=0 Then
I also have XSLT Code ... but you need Altova Community Edition
Set objAltovaXML = CreateObject("AltovaXML.Application")
Set AltovaXMLXSLT2 = objAltovaXML.XSLT2
AltovaXMLXSLT2.InputXMLFileName=vs_1
AltovaXMLXSLT2.XSLFileName ="C:\Data_Server\Onehub\AAA_Data_OneHub\SV2\Data_VDrive\Data_QDrive\Febooti\FilterForge.xsl"
output = AltovaXMLXSLT2.Execute(outputfile) 'outputfile irrelevant
Set AltovaXMLXSLT2 =Nothing
Set objAltovaXML = Nothing
End if
End Sub
Function ReadTextFile(vs_1)
'Make sure that Febooti does not save unicode which is default
if 1=0 then
set adb = CreateObject("ADODB.Stream")
adb.Open
'.Type = adTypeBinary
adb.LoadFromFile vs_1
adb.Type = 2 'adTypeText
adb.Charset = "ascii" '"utf-8"
strText = adb.ReadText(-1) '
adb.Close
adb.Close
end if
Const ForReading = 1
Set objFSO = CreateObject("Scripting.FileSystemObject")
'WScript.Echo( vs_1 & len(vs_1))
Set objFile = objFSO.OpenTextFile(vs_1, ForReading)
'WScript.Echo( "End")
ReadTextFile = objFile.ReadAll()
'ReadTextFile = objFile.ReadLine
objFile.Close
set objFSO =Nothing
End Function
Sub WriteTextFile(vs_1,vs_2)
Set fso = CreateObject("Scripting.FileSystemObject")
'OpenTextFile Parameters:3.'-Filename4.'-The 2 is for writing... 1 is reading and 8 is appending5.'-The "True" is to create if not already there
Set fl = fso.OpenTextFile(vs_1, 2, True)
fl.Write(vs_2)
fl.Close
Set fl = Nothing
Set fso = Nothing
End SUb
Sub SDeleteFile(vs_2)
'Turn off error handling
On Error Resume Next
'file might not exist
'Create an instance of the FileSystemObject
Dim objFSO
if objfso.fileexists(vs_2) then objFSO.DeleteFile(vs_2)
set objFSO = Nothing
End Sub
Function GFMatch(strString, strPattern, wglobal, wignorecase, wmultiline)
Dim RegEx, arrMatches
Dim colmatches
Dim wmatch
Dim Count
Set RegEx = New RegExp
RegEx.IgnoreCase = wignorecase
RegEx.MultiLine = wmultiline
RegEx.Global = wglobal
RegEx.Pattern = strPattern
Set colmatches = RegEx.Execute(strString)
Count = 0
For Each wmatch In colmatches
Count = Count + 1
If Count = 1 Then GFMatch = wmatch
Next
End Function
Function GFMatchArray(strString, strPattern, wglobal ,wignorecase ,wmultiline)
Dim tmatcharray()
xdim = colmatches.Count
ReDim Preserve tmatcharray(xdim)
Count = 0
Count = Count + 1
tmatcharray(Count) = wmatch.Value
Next
GFMatchArray = tmatcharray
End Function
Sub sortarray(arrayname, sortcolumn1)
' sortcolumn1 = 0
'Optional wnumeric As String = "numericstrings"
For i = LBound(arrayname, 1) To UBound(arrayname, 1) - 1
For j = LBound(arrayname, 1) To UBound(arrayname, 1) - 1
If wnumeric = "numericstrings" Then
Condition1 = CDbl(arrayname(j, sortcolumn1)) > CDbl(arrayname(j + 1, sortcolumn1))
Else
Condition1 = (arrayname(j, sortcolumn1)) > (arrayname(j + 1, sortcolumn1))
End If
If Condition1 Then
For Y = LBound(arrayname, 2) To UBound(arrayname, 2)
t = arrayname(j, Y)
arrayname(j, Y) = arrayname(j + 1, Y)
arrayname(j + 1, Y) = t
Next
End If
Next
Next
End Sub
Function TransposeDim(v)
' Custom Function to Transpose a 0-based array (v)
Xupper = UBound(v, 2)
Yupper = UBound(v, 1)
ReDim tempArray(Xupper, Yupper)
For X = 0 To Xupper
For Y = 0 To Yupper
tempArray(X, Y) = v(Y, X)
Next
Next
TransposeDim = tempArray
End Function
Please, has this been fixed in FF 4.010 ? or is this going to be fixed in FF 5.0?
Sorry that I could not be able to check it myself if it is fixed or not
As in the forum this post will appear the first I repeat what was the problem
SpaceRay wrote in 2013:
Ctrl+Z works correctly for me in 4.014.
Thanks very much for the good news and good to know that it has been fixed, as this was a bad thing
