Introduction: Most of the filters I make are pretty straight forward. Once in a while, though, I create technical snippets that definitely do something useful, but fail to find home in a creative application (given several mild limitations in FilterForge alone.) These snippets are esoteric, technical, might be unusual, often having specific usage and otherwise but might find home in unexpected places.
So I thought I'd just put them on the forum as a challenge. The base goal is this: make something creative with it. As a bonus fun / loose rule for fun: use the snippet as-is without adding/subtracting/rearranging the structure (parameters are ok for tweaking). (Note: this is just a fun rule. Nobody needs to follow it strictly.)
Hopefully even if the stuff here gets a bit expert-oriented, it might be just interesting on its own.
Just to kick start this whole thing here's a small demo using the loop feature to count the probability of source A being > 50 (or any other operation). Discrete probability!
Snippet is attached below. Only opens in FF4.0.
Discrete Probability.ffxml
xirja
Idididoll Forcabbage
Intriguing, I'll have to look into it! smile:)
14 unregistered users.
