Mahlikus The Black
Graphic ninja
One of my favorite filters is 'Engraving' by Vladimir Golovin. I was wondering if there is a way to edit the filter to insert a global rotation on the filter. I LOVE what it does to an image but I would like to rotate the filters effects on a global scale so I can create custom contour hatching. Any info would be greatly appreciated.
~MAH~
PS - Sorry if this is a Noob question but I am literally 10 days in on this filter. Thanks again yall.
~MAH~
Without looking at the filter, I would guess that adding a Transform/Rotate component after the input image and another with the same amount of rotation to the other direction right before Result might do the trick.
266 unregistered users.
