Hello, I have seen on many filters that there are curves components attached to the profile in Noise components to get different results.
For example this one taken from the well done Asteroid by Rawn (RawArt) |
| Posted: October 6, 2013 12:03 pm | ||
Although in the title is put for Noise components, it can be used also the Curves for other components like gradients components or patterns components, and probably others that can be modified by this curves.
And what I want is to know some advice, hints and tips for using this curves with noise components (and also other ones) and know wich curves would give better result with which component and from your experience what do you use and how do you them. |
| Posted: October 6, 2013 12:19 pm | ||
267 unregistered users.
