inujima
inujima
And button.
Nice! It looks better if you use the scratches in the height instead of the surface color.
inujima
Yes! This LP record uses scratches in the bump map.
Yummy.
inujima
improved version
inujima
gold disc
inujima
It can create a more realistic reflection from blending with a mirror reflection render using photoshop.
This is really cool.
inujima
Vinyl Record Disc filter beta version for FF4.
Vinyl Record Disc v1.1b.ffxml
Incredible!
WOW!! Excellent creation of very well done and realistic Vinyl Records and not only in black or grey, also on gold and silver!! Congratulations
Really MUCH better than the available ones already in the library
And like very much all the many settings, and well chosen and descriptive names smile:D, that are included and available to really customize much the disc and very well done how you have solved the central label part, and having 2 options for image, and to be able to scale it even if it is not prepared with transparent background or you want to show only a part of the image.
This is like a vinyl´s factory with many materials
lol anti-alias wasn't done in your render.
And you could use the well done and great FF filter Iris by Nebbie by Nebreah2 for the label as shown here below
Here is an example using the double image feature, the red flower have a transparent background and using a turbine engine as label background
I have also thought the same as you when I have seen the result, but I have seen that by default, it really has 17 samples Edges only Antialias active, BUT you are right that there is antialias missing fully in the green one, as I have seen when making this example below, that in this case, you must wait until ALL is rendered completely for the AA to be applied fully (on some other filter this does not happen), so it was my error when I took the screenshot too early, good one that you have spotted it smile;)
Also is curious and nice when you use the seamless setting
inujima
Demo Render of new version of Vinyl Disc filter.
ddaydreams
Frank Hawkins
Wow, looks better than real, if that's even possible smile:)
That's got soul, that filter! smile8)
23 unregistered users.
