Ouroboros
Ouroboros
Hi!
I need to modify bomber, I have no idea if this is possible:
-Make the bomber choose the color of the particle from only one pixel
-Input a second image that determines the angle of the particles
We can work through elance or whatever, thanks
Paul
Well you can't modify the bomber itself but you add other components to it...This will result in final task that you need.....btw what is the final task that you hope to achieve?.....You can contact me through the email button in this post... smile;)
jitspoe
Filters: 27
What you're trying to do may already be possible. I'm not sure what you mean by "only one pixel", though. Do you want the first pixel in the image to determine the color of every particle? Through some use of other components (ex: scale and tiles), you could probably blow the entire image up into a solid color from one pixel, then use that to color the particles or pass it into the tint.
For the second part, you can already pass in a component to determine particle rotation, so just pass an image into that...
Tint Color and Rotation are the inputs you're looking for! Just plug something into them, that's how FF is supposed to work! smile:-p
11 unregistered users.
