| James |
With some of the filters looking very 3D i was just wondering are any of you guys using FF for GUI design, i plan on making some stuf at some point, mainly a shaped buttons and sliders ect, i was just wondering is somthing like Logic Audio's Sculpture possible with FF?
http://www.apple.com/logicpro/sculpture.html Any of you guys attempted to use FF in general/non texture design and making stuff like this? |
| Posted: November 10, 2006 5:05 am | ||
| James |
Some more great GUI examples -
http://www.motu.com/products/software.../body.html http://www.motu.com/products/software/mx4 http://www.ultimatesoundbank.com/zoom.php?id=79 This is the type of thing im going to aim for as i think they look amazing. |
| Posted: November 10, 2006 5:12 am | ||
John Michaud
From what i understand and have seen of what FF is capable of, making GUI buttons would be a fairly easy thing to accomplish. For Example:
http://www.filterforge.com/filters/1154.html Its simplistic in its construction, and quite convincing too Hope to see your filters soon! |
| Posted: November 10, 2006 6:33 am | ||
| James |
Hey thanks that looks great, yeah thats just the type of thing i wanted, i havent had much free time yet but im going to try and work out how to raise certain parts of the pannel and have indents/grooves ect, im guessing if i fill the whole pannel with a grey then have the indents as darker and rises as white/lighter then give it a plastic/metalic texture that could look great, i wonder if its possible to use an imported image from photoshop like this and use it as a template type thing. should be fun
| Posted: November 11, 2006 11:39 am | ||
| James |
Anyone else using FF for non texture uses? Tonight im going to stay up so i will probably make a few. Is there any way to downsize a shape either in H or V directions? Like make a square to a rectangle type thing?
| Posted: November 18, 2006 6:31 pm | ||
| Posted: November 18, 2006 6:44 pm | ||
| James |
No, i mean like a solid shape this would be, like a website type pill button shape, like for example you start with a rounded square, then convert this to a rectangle pill (smaller in vertical size) like a filter that applys a resize but keeps the shape and without repeating the shape.
| Posted: November 18, 2006 7:12 pm | ||
You could use the frame component with fixed size on and play with the corners slider. If you used a rectangular image on a frame component with corners set to 100, it would give you a perfectly pill shaped button of that size.
| Posted: November 18, 2006 7:21 pm | ||
| James |
Ok, thanks for the tip, im going to try and make a few elements that you might see on a synth, buttons, knobs and sliders and that type of thing, i will post some of my progress soon
| Posted: November 18, 2006 7:23 pm | ||
Here is a simple button that I made with frame components. Nothing spectacular, but it's one possible technique. I was exploring some alternatives to how I created buttons in my Power Button filter.
Simple Glossy Button.ffxml --- Crapadilla says: "Damn you, stupid redundant feature requests!" ;) |
| Posted: November 18, 2006 7:26 pm | ||
| James |
I just made this slider button which is ok i guess, im not amazing at filter building though, but the structures fairly complex for how simple it looks, i will post the filter to the library soon
| Posted: November 18, 2006 8:46 pm | ||
| James | ||
| Posted: November 18, 2006 10:31 pm | ||
Coming along nicely. The second one appears to be unsure whether he would like to be graphical or realistic tho!
| Posted: November 19, 2006 6:59 am | ||
| James |
Thanks, yeah the second one wasn't quite as great as i was hoping, im quite pleased with the slider control though.
| Posted: November 19, 2006 8:35 am | ||
