| Posted: September 11, 2012 2:06 pm | ||||
| Posted: September 11, 2012 2:22 pm | ||||
Nifty...Now make it a histogram...
| Posted: September 11, 2012 5:31 pm | ||||
| Posted: September 12, 2012 2:35 am | ||||
Very cool and nicely done. Great
| Posted: September 12, 2012 2:42 am | ||||
Just add ffbatch and watch it go round.
| Posted: September 12, 2012 3:45 am | ||||
Good and well done seeing it go round, but would be even better if the lines could be animated and not still as you have done on another example made before
FFBatch is only for MAC, so Windows users can´t do it |
| Posted: September 12, 2012 5:23 am | ||||
| Posted: September 12, 2012 5:36 am | ||||
Considering I did this animation on Windows with ffbatch, that seems inaccurate. Unless you meant it the other way 'round. |
| Posted: September 12, 2012 7:17 am | ||||
So when you rotate the grid, what exactly is going on in the filter?
| Posted: September 12, 2012 7:42 am | ||||
I rotate it from the top view before tilting it back in perspective and smudging for height.
There are actually two separate images used, one for the height, one for the color: The height information has the four corners of each unit at different levels and the color information source has them at the same height so I can map flat colors onto each face. I'm using Sphinx's method to offset the Lookup coordinates rather than the image directly, which makes it smoother. |
| Posted: September 12, 2012 7:59 am | ||||
| Posted: September 12, 2012 8:09 am | ||||
