I have seen this image shown below, and then I thought that is of course possible to make in Filter Forge, and would be a good idea, and use any kind of transparent background images or photos to fill the squares.
I wonder if a filter like this has already been done before and is available, or if not I could be able to make one, as this I think would not be very difficult to make, and does not need to know complex maths or any special FF components.
And possibly it could include also the ability to add textures to the squares.
Here is the example I have seen that could be the model for the filter if it is not already done and available
I have tried to make something like this as there has been no answers and I have not found anything like this in the FF library
This is just a preview, my real idea is to be able to make real images with transparent backgrounds and not only flowers made in FF.
And in this examples ALL are flowers but I could any other figure instead of these.
and this other one
with 7 columns as the example shown
and with real photo flowers now
with 7 flowers
And changing the background for different colors and still having a small frame
And now without frames and have all the background white so is more like the first example on the first post
I like the last two examples the best smile:)
Thanks, I also think the same as you, this last ones are the best ones, I will continue making this and then upload it to the library.
23 unregistered users.
