Akiro
Yesterday I tried to download a few filters for photoshop but each time I pressed the key for download, it asked if I wanted to open this external program, or do nothing.
Unfortunately I pressed do nothing but at the same time I had put a checkmark in "remember this answer" and now I cant get any filters to download/transfer to FilterForge. What can I do so I again can download the filters from the mainpage?
Thank you!
you can use another browser as this settings are stored in the browser configuration and not in Filter Forge
If you have already Filter Forge open before downloading will be easier than if it closed
and there is no problem in saying yes to open external application if it is for Filter Forge
Sharandra
Filter Forge Addict
If you´re using Firefox, go to Tools > Options > Applications and scroll through the list until you find Filter Forge. Then set it to "Use Filter Forge".
