voldemort
voldemort
Filters: 649
Im creating a strictly zoom filter that resizes the photo here is the kicker Im going to make 12 preset sizes and need to make sure the controls are absolutly locked except for the one I provide yet sometimes filter forge randomizes stuff that isnt marked with controls
Is there a way to lock theese feetures I thought I read some where you could but dont recall where
Thanks
voldemort
voldemort
Filters: 649
Well I would still like to know how but its no rush now durring break I monkeyed with it a bit to add more zoom levels and when I went to save it ff bombed and its now 0kb and invalid so I should have made incrimental versions of it and Im to bumbed right now to restart since it was very time consuming to make 50 different zoom levels smile:cry:
voldemort
voldemort
Filters: 649
If any one else is curious and wants to do it since I probably wont for a while
step one 2 profile gradients
gradiant a = 0 rotation
gradiant b = 90 rotation
add a level curve
invert the curve
now do a slight slope to it
use this as the profile for both gradients
now add a offset
gradient b = v for offset
gradient a = h for offset
source your photo
add a second offset
source your previous offset
offset h -100
offset v -100
percentage == use this to center the resized photo
now add a frame component
contents white
inner frame black
outer frame black
corners 0
margin 0
frame width (will be controlled)
now add a set alpha component
your frame will be the oppacity
the source your last offset
you now have a resized photo
I used two switches one filled up with the first levels of zoom the other with the smaller zooms
then connected them with a third switch that allowd you to choose the level of zoom and whether it was a colored background or the orriginal photo as background
all in all I had 20 zoom levels to the riddiculously tiny levels
voldemort
voldemort
Filters: 649
Well I went ahead and redid it and submitted it in two forms a simplistic one that goes from about 75% to just a few pixels to one thats complicated controlls to allow fine tuneing but has pressets from 99% to just as small as the first one this filter expects a picture with a 1-1 dimmension ratio since for the alpha I cheated and used the frame control to set the alpha
