Generate a curve or gradient map like the one seen here...
Rules: -Random -Periodic (tiles properly) -Angles vary -Up/Down/Up/Down pattern (every time) -Every point in unique vertical position -Possible for "valleys" to be higher than "mountains" -Horizontal spacing mostly homogenous. My solution to the problem involves a cell noise, checker, and a profile gradient. But I wanted to see if someone had a more clever solution. *Note the attachment is my untouched Curve To Shape filter which will let you output your curve as an image... [snip] Curve to Shape uberEDITION v2.0.ffxml |
| Posted: June 11, 2012 3:59 am | ||
I was going "Oh it shouldn't be that hard" and I was so wrong.
Periodic (tiles properly) <--- I get stuck here. |
| Posted: June 11, 2012 8:35 am | ||
| Posted: June 11, 2012 10:15 am | ||
damn D:
| Posted: June 11, 2012 11:33 am | ||
the second one is easy, i've done it many times. not sure of the first. profile gradient and 3 or 5 color gradient, threshold (i think. doing this fr om memory) you could probably alos use that new curve component, the one wh ere you set the points.
| Posted: June 11, 2012 12:52 pm | ||
| Posted: June 11, 2012 8:37 pm | ||
| Posted: June 11, 2012 9:07 pm | ||
