Can anyone tell me if the 4.0 Beta is rendering 5000 x 5000 ppi and above images "without" the "Bad Allocation" errors that are in 3.0???
StevieJ as you can see in this other thread made by Sharandra with the FF 4.0 Beta 1, regretably it has NOT been solved yet.
Bad allocation error go away!
As seen also in this thread
We're working on it!
Look at all these bumps today... SpaceRay....
smile:!: This bad-allocation problem is a serious issue and does affect a bunch of people. Don't bump threads that serve little or no lead to a solution. Most of these threads don't have any lead to a solution so I suggest you not to bump any of them. Do not make lists of links to other threads that have no lead to a solution. Otherwise choose the right ones that serve your point.
People are searching for solutions to a major issue. If anything, bumping and linking to threads with no end or no lead to a solution only wastes people's precious time and it adds to their frustration and disappointment. Avoid agitating the forums. Keep the forums clean and respectable.
Skybase is right: please don't bump multiple threads.
+12 new in 30 days!
