Topics 1 - 45 of 1410
First | Prev. | 1 2 3 4 5 | Next | Last | All
  Topic Starter Replies Views Last Post
New posts! Sticky: Feature Wishlist Vladimir Golovin 40 32720 by Ghislaine
August 24, 2022
New posts! Sticky: The best way to contact us Bella 0 8418 by GMM
September 10, 2007
New posts! Component Instances AussieDecalf 4 4931 by AussieDecalf
August 27, 2025
New posts! Would it be possible to have a TEXT import into FF as a component? SpaceRay 12 12962 by Rod_D
June 12, 2025
New posts! Would be good to have in forum a ADD-ONS specific category SpaceRay 0 1139 by SpaceRay
March 19, 2025
New posts! GPU Revisited JB55 2 2811 by SpaceRay
January 3, 2025
New posts! Color range selector Ramlyn 6 2931 by Ramlyn
November 15, 2024
New posts! New components Ramlyn 7 3888 by SpaceRay
June 1, 2024
New posts! Be able to input video into bomber and not only still images SpaceRay 0 1120 by SpaceRay
January 8, 2024
New posts! Adding webm to forums Rachel Duim 1 1667 by Carl
December 29, 2023
New posts! Storing filter and settings as output image metadata ALZHEM 2 1893 by GMM
December 18, 2023
New posts! Dropdown list James 11 10987 by Beat
November 22, 2023
New posts! Tag Sorting Prototype458 3 1937 by GMM
October 20, 2023
New posts! Component to Fill Contiguous Regions with Parametric Colors Furyofaseraph 0 1263 by Furyofaseraph
October 8, 2023
New posts! Editable and Organizable Snippets? Furyofaseraph 0 1183 by Furyofaseraph
October 8, 2023
New posts! Tint Chaos for Bomber Component Novaesky 7 2371 by SpaceRay
September 27, 2023
New posts! New Effects Categories for Animate Filters or search to find them John Foll 5 2622 by GMM
September 1, 2023
New posts! Rearranging file locations Kraellin 3 4840 by Lucato
July 27, 2023
New posts! FF13 (BETA13) - Render multiple frame ranges STEPH08 0 1347 by STEPH08
July 19, 2023
New posts! Portrait / Landscape presets Rachel Duim 0 1308 by Rachel Duim
June 28, 2023
New posts! small wishes ronviers 0 1581 by ronviers
May 20, 2023
New posts! Render GIF animation with transparent background L95 5 2136 by GMM
March 21, 2023
New posts! Numerical switch Ramlyn 0 1207 by Ramlyn
February 22, 2023
New posts! 3ds Max Filterforge integration Macphisto 14 12484 by Shawn Olson
January 5, 2023
New posts! Request for Render Farm: multiple command line instances ALZHEM 4 4364 by Fatal Strategies
December 11, 2022
New posts! Rectangular images need an indication of the center STEPH08 0 1241 by STEPH08
November 9, 2022
New posts! Rendering time should be always displayed after the rendering strip or STEPH08 0 1359 by STEPH08
November 1, 2022
New posts! FF 11 Plugin KenS. 2 31272 by KenS.
October 30, 2022
New posts! Video? You should switch the engine from CPU to GPU. STEPH08 1 2252 by STEPH08
October 27, 2022
New posts! Filters using non-square previews images Ramlyn 3 1651 by Ramlyn
October 15, 2022
New posts! Be able to have the FF Filter Snippets INSIDE the filter editor to use SpaceRay 25 8059 by GMM
October 14, 2022
New posts! Drag & drop snippet from filter list in main window into editor rgoer 5 3337 by GMM
October 14, 2022
New posts! Capsules: Custom Components Crapadilla 4 3819 by GMM
October 14, 2022
New posts! FF Forum to support embedded video links now that FF 11 has video SpaceRay 0 1386 by SpaceRay
August 25, 2022
New posts! Support for WebM Christian.B 0 1550 by Christian.B
August 6, 2022
New posts! Be able to duplicate a component WITH the connected links included SpaceRay 5 9835 by SpaceRay
August 3, 2022
New posts! FF Function library in lua Sphinx. 2 2790 by David Roberson
July 31, 2022
New posts! Add Animated Filters Render to Mp4 file and preview animation John Foll 3 1989 by GMM
June 15, 2022
New posts! Add ability of entering text which would render font in Image or Anima John Foll 2 3267 by John Foll
June 15, 2022
New posts! Repper Type Function Using FF Engine Valhalla 13 6408 by Valhalla
June 4, 2022
New posts! Bomber Improvements (Pages: 1 2 3 ) Neil Blevins 120 24106 by SpaceRay
March 31, 2022
New posts! Unit component ThreeDee 14 9951 by SpaceRay
March 31, 2022
New posts! Custom Channel Export / Render Queue Martin Naumann 5 2705 by GMM
February 9, 2022
New posts! Rename Layer with Name of Filter Applied CattailNu 0 1422 by CattailNu
January 6, 2022
New posts! Bomber Plus -- Density -- Max value of 20 not enough uberzev 2 2641 by uberzev
January 3, 2022
33,849 Registered Users
+12 new in 30 days!
+7 new in 7 days!
15,392 Topics
+44 new in year!
