Topic |
Starter |
Replies |
Views |
Last Post |
Sticky: Feature Wishlist
Vladimir Golovin |
40 |
32913 |
by Ghislaine
August 24, 2022
Sticky: The best way to contact us
Bella |
0 |
8466 |
by GMM
September 10, 2007
New IntSlider control
Ramlyn |
1 |
497 |
by Ramlyn
October 5, 2026
Component Instances
AussieDecalf |
4 |
4995 |
by AussieDecalf
August 27, 2025
Would it be possible to have a TEXT import into FF as a component?
SpaceRay |
12 |
13130 |
by Rod_D
June 12, 2025
Would be good to have in forum a ADD-ONS specific category
SpaceRay |
0 |
1182 |
by SpaceRay
March 19, 2025
GPU Revisited
JB55 |
2 |
2908 |
by SpaceRay
January 3, 2025
Color range selector
Ramlyn |
6 |
3003 |
by Ramlyn
November 15, 2024
New components
Ramlyn |
7 |
3934 |
by SpaceRay
June 1, 2024
Be able to input video into bomber and not only still images
SpaceRay |
0 |
1157 |
by SpaceRay
January 8, 2024
Adding webm to forums
Rachel Duim |
1 |
1715 |
by Carl
December 29, 2023
Storing filter and settings as output image metadata
ALZHEM |
2 |
1942 |
by GMM
December 18, 2023
Dropdown list
James |
11 |
11042 |
by Beat
November 22, 2023
Tag Sorting
Prototype458 |
3 |
1973 |
by GMM
October 20, 2023
Component to Fill Contiguous Regions with Parametric Colors
Furyofaseraph |
0 |
1307 |
by Furyofaseraph
October 8, 2023
Editable and Organizable Snippets?
Furyofaseraph |
0 |
1223 |
by Furyofaseraph
October 8, 2023
Tint Chaos for Bomber Component
Novaesky |
7 |
2431 |
by SpaceRay
September 27, 2023
New Effects Categories for Animate Filters or search to find them
John Foll |
5 |
2674 |
by GMM
September 1, 2023
Rearranging file locations
Kraellin |
3 |
4903 |
by Lucato
July 27, 2023
FF13 (BETA13) - Render multiple frame ranges
STEPH08 |
0 |
1396 |
by STEPH08
July 19, 2023
Portrait / Landscape presets
Rachel Duim |
0 |
1340 |
by Rachel Duim
June 28, 2023
small wishes
ronviers |
0 |
1622 |
by ronviers
May 20, 2023
Render GIF animation with transparent background
L95 |
5 |
2183 |
by GMM
March 21, 2023
Numerical switch
Ramlyn |
0 |
1241 |
by Ramlyn
February 22, 2023
3ds Max Filterforge integration
Macphisto |
14 |
12541 |
by Shawn Olson
January 5, 2023
Request for Render Farm: multiple command line instances
ALZHEM |
4 |
4422 |
by Fatal Strategies
December 11, 2022
Rectangular images need an indication of the center
STEPH08 |
0 |
1281 |
by STEPH08
November 9, 2022
Rendering time should be always displayed after the rendering strip or
STEPH08 |
0 |
1394 |
by STEPH08
November 1, 2022
FF 11 Plugin
KenS. |
2 |
31318 |
by KenS.
October 30, 2022
Video? You should switch the engine from CPU to GPU.
STEPH08 |
1 |
2328 |
by STEPH08
October 27, 2022
Filters using non-square previews images
Ramlyn |
3 |
1695 |
by Ramlyn
October 15, 2022
Be able to have the FF Filter Snippets INSIDE the filter editor to use
SpaceRay |
25 |
8118 |
by GMM
October 14, 2022
Drag & drop snippet from filter list in main window into editor
rgoer |
5 |
3369 |
by GMM
October 14, 2022
Capsules: Custom Components
Crapadilla |
4 |
3868 |
by GMM
October 14, 2022
FF Forum to support embedded video links now that FF 11 has video
SpaceRay |
0 |
1426 |
by SpaceRay
August 25, 2022
Support for WebM
Christian.B |
0 |
1587 |
by Christian.B
August 6, 2022
Be able to duplicate a component WITH the connected links included
SpaceRay |
5 |
9876 |
by SpaceRay
August 3, 2022
FF Function library in lua
Sphinx. |
2 |
2841 |
by David Roberson
July 31, 2022
Add Animated Filters Render to Mp4 file and preview animation
John Foll |
3 |
2035 |
by GMM
June 15, 2022
Add ability of entering text which would render font in Image or Anima
John Foll |
2 |
3321 |
by John Foll
June 15, 2022
Repper Type Function Using FF Engine
Valhalla |
13 |
6486 |
by Valhalla
June 4, 2022
Bomber Improvements
(Pages: 1 2 3 ) |
Neil Blevins |
120 |
24259 |
by SpaceRay
March 31, 2022
Unit component
ThreeDee |
14 |
10015 |
by SpaceRay
March 31, 2022
Custom Channel Export / Render Queue
Martin Naumann |
5 |
2757 |
by GMM
February 9, 2022
Rename Layer with Name of Filter Applied
CattailNu |
0 |
1460 |
by CattailNu
January 6, 2022
