| ddaydreams |
I have ff3 running as a stand alone app.
I would like to apply an FF3 effect to a selection (AKA masked area) in a document that I have opened in photo shop. What's the work flow here? Do I have to run FF3 as a photoshop plugin to do this? or can I somehow export my photoshop doc in some format that would retain the mask (aka selection) and open (import) that into FF3 to apply filter to the selected area of the document? Thanks for any help. |
| Posted: March 16, 2012 12:47 am | ||||||
I think that the only EASY way to apply an FF3 effect to a selection is made with FF3 as a photoshop plugin to do this
BUT I think that could be possible yo do it perhaps in the standalone if you save the selection in the document as an alpha channel (all the saved selections are alpha channels) and then in the standalone FF you must select that alpha channel included in the document Do not ask me HOW to do this, because I do not know really and have not tried myself, and I is more difficult to do. Why not choose the easy way and make this inside Photoshop with FF as a plugin? Is there any reason you may have to prefer doing it in the standalone? |
| Posted: March 16, 2012 3:52 am | ||||||
UPDATE
I have found this below that perhaps could be useful for you
http://www.filterforge.com/more/help/...ction.html and here is more detailed
| Posted: March 16, 2012 4:10 am | ||||||
| ddaydreams |
I can't figure out how to install it as a Photoshop plug in. Also concerned about loosing presets if I attempt reinstall. Also I did not want to re download all the filters again I'm win 7 64 bit with photoshop CS5.1 extented. I don't remember if or where I'm given a choice to install FF3 as a plugin. Or if it has to done manually by dragging files around |
| Posted: March 16, 2012 1:01 pm | ||||||
The Filter Forge photoshop plugin is installed automatically IF photoshop is installed already when you are going to install Filter Forge, and it detects very well where it is and shows you it in the install.
Anyway, if it is not installed, the only thing you have to do is copy the 64 bit version of .8bf file of filter forge inside the Photoshop plugins folder and that is all.
Perhaps could be helpful for you this threads where you can see where are the presets and filters and so you can make a backup and do not be afraid to loose them. Guide to how to backup your FF filters library from your hard drive Where are the downloaded Filter Forge filters located physically? |
| Posted: March 16, 2012 2:24 pm | ||||||
| ddaydreams |
Thanks for the help.
Before I had posted I had tried to drag the 64 bit.8bf file and drop it into the photoshop plugins folder and the 8bf disappeared when I tried that. So I could no longer find that file. So finally after reading your reply I wound up doing a reinstall at which point the installer detected my 64bit photoshop and I just checked the box next to that. It installed fine and did not loose my filters or presets. So I'm good to go now. Thanks Again |
| Posted: March 16, 2012 6:43 pm | ||||||
Glad to help and that you have been able to solve it
| Posted: March 16, 2012 10:50 pm | ||||||
