I do not know if you already know about the beautiful, wonderful and amazing results you can get with carefully prepared panoramic photos and the photoshop polar coordinates filter to make Polar Coordinates Panoramas
I think that this could be done in Filter Forge but do know it would be possible
How to Create Your Own Planets Using Your Panoramas
http://content.photojojo.com/tutorial...a-planets/
http://www.flickr.com/photos/diegofot...08326@N00/
http://www.flickr.com/photos/dirkpaessler/164124874/
http://www.flickr.com/photos/dirkpaessler/3904448343/
and more here ---> http://www.flickr.com/photos/dirkpaes...164124874/
AND MORE THAN TEN THOUSANDS MORE here ---> http://www.flickr.com/photos/dirkpaes...164124874/
And if you tink that spheric planets are not so good, you can make then cube style
AND ALSO here some more
50-dazzling-examples-of-polar-panorama-photography
http://www.webdesignerdepot.com/2009/...otography/
AND EVEN MORE HERE
30+ Examples & Tutorials of Stunning Polar Panorama Photos
http://www.hongkiat.com/blog/30-examp...ma-photos/
AND MORE HERE
http://weburbanist.com/2009/03/08/pol...otographs/
[img][/img]
And another FLICKR Polar Coordinates Panoramas group
http://www.flickr.com/groups/43428515@N00/
Andrew B.
Filters: 2
You might find this interesting: http://www.flamingpear.com/flexify.html
I am sure this could be modified to work with panoramic images...
Polar Type o Filter
Thanks for the link, you are right that this is a very good plugin, but I have not bought it already, as I have prefered to buy FF 3.0 upgrade and other things before this, also thanks for remembering that I have found about this flexify before some time ago, but as this was not important and have a priority I have not bought it, the same as the excellent Fractalius that also have not bought either
ALSO if you go to the end of the page on the first link hereyou will see that this is put also.
The Flexify filter module ($35) for Adobe Photoshop creates polar panoramas on-the-fly and offers numerous projections for your photos.
Polar Type o Filter
Thanks for the link, I did not that there was already a spherify filter smile:), although as you say it surely must be modified, because the "magic" or trick to make this small planets, is that you need large rectangular photos well prepared before applying the filter,
As far as I know FF works better with square and normal rectangular photos, although really do not know what happens with large and long rectangular panoramic photos and a FF distortion filter applied to them, should try and see.
UPDATE: I have already tried the Spherify filter as suggested by CFandM and it has no surprising effect, as I already knew, FF likes much better SQUARE photos on some filters, because if not you get weird and funny results like this one shown here below smile:D
Some filters are prepared for rectangular photos as you can see with the very good
Spherical Projection by Inujima
This is the default preset 1
BUT not only makes spheres, ALSO uses the polar coordinates to make great and weird 2D photo effects as shown below
This is made with the same photo but selecting preset 4 and nothing else changed
And also using the interesting preset 5 you can get things like this here
And modifying the preset five and change the setting of Repeat V to "2" you get this
And continue modifying the preset five and change the setting of Repeat V to "3" you get this smile:D
And what happens if in preset 5 you change setting of Repeat V to "7" ? smile:?:
You get this below smile:D
The Wild Orb Perspective filter by voldemort (the king of distortion filters) is NOT prepared for rectangular photos as shown here with starnge and weird effects and is does not work at all well as it happens with the well done inujima filter above smile:D
Trying also the other presets give the same weird result and wrong result
ALSO happens the same wrong errors with the 3D Sphere by ThreeDee as ALSO is ONLY configured for SQUARE photos.
Well here you go SpaceRay getting me sidetracked again.. smile:dgrin: smile:angel: smile:D
Here is an updated version of the filters link I posted a couple of posts up....This one I updated to work....Not quite finished..Still needs some controls to adjust the image....But go to the settings to load the panoramic image....Then you can select the new image for the finished size.....
Panoramic Planets.ffxml
smile:D YES smile:D I know you like challenges and filter suggestions. Thanks very much for trying to make a filter for this kind of things.
I have tried your new updated version Panoramic Planets but regretably it does not work well for me, it does not make an sphere or a planet like the ones above smile:?: I am doing it wrong ? smile:?:
What settings must be put ?
I have tried 3 different photos and had very bad result even trying with different settings
For example I have taken from the very first link this photo here as source for your filter
AND I should be getting this result
AND what I get with your filter is this shown below with scale 1,2 and size 2000, and I am showing the best I could make as there are many worse versions smile:D
I have found something strange !! If I open the Filter editor the final component shows a DIFFERENT preview than the one Filter Forge gives as a result, as in the tiny small preview of the "Result Source" you can see a much better panoramic AND you can see the WATER in the center, and in the end result shown above there is NO water anywhere seen
Please see this screenshot here below
Also I have seen that the Flexify 2 filter is really very complex and have many options, and have LOTS AND LOTS of Output options in MANY different shapes.
Also they say that they have a "1-click little planets" !!! as shown here
I also have seen that the price have risen from 35$ to 45$ !!
Although before buying, there is a downloadable free trial version smile:) And also have seen that the user guide included in the demo have 79 PAGES !!! smile:eek: smile:eek:
You must have grabbed that old version before I updated it.......Heres the newest version for now.......
As I said still needs work and options to do various things......One note....Create a new image by going to the File menu then new image then create a square image....Then go to the settings tab on the filter and load the panoramic image from there......
SpaceRay Wrote..
I have tried your new updated version Panoramic Planets but regretably it does not work well for me, it does not make an sphere or a planet like the ones above I am doing it wrong ?
Nope...Its that square issue...I have just submitted a polar distortion snippet that is for the non square and square images....I will be using this in a little planet filter.. smile;) smile:) Heres a result compared to photoshop...I tried other images also and the results were the same.....Heres FF....
Then heres PS
This is realy great, finally there is a really good polar distortion filter that WORKS WITHOUT that bleeding rays outside of the circle as seen very well in the Photoshop version. Thanks.
Yep and it works with the non-square images... smile;) smile:)
btw heres that planet filter so far.....When using this filter go to the menu and select "New Image" then make that image square...(Still working on that part)......Then go to the "Settings" tab on the filter and load your panoramic image in the control marked for that.........
Panoramic Planet.ffxml
OH YES!!! this a very important thing !!
Thanks for the filter I will give a try and see what you have until now
Heres a quick result from the submitted polar filter.....
Looking good!
How about some panoramic shapes to go with the planet..... smile;) smile:)
Then one more.....
Love that square one smile:D
I gave CF's filter a try (but I replaced the frame with a free gradient so it would work with non-square images).
I like the shapes, too.
Great and lovely filter you have made, Here I have made an example, but this was just a quick one, surely that preparing carefully the photo to be used with this filter I will get much better results.
Indigo Ray Wrote..
Yep that works better...I have that in the version that I am submitting.....The shapes are fun...They look cool as anaglyphs also... smile;) smile:D
Morgantao..
smile:D smile:)
Thanks SpaceRay and yep gotta prepare that image to line up..... smile:)
It has not been said here that CFandM have already made available his great and lovely filter and that works very well.
POLAR DISTORT BY CFandM
http://www.filterforge.com/filters/10289.html
And I have put lots of very good examples using this filter in this thread here
http://filterforge.com/forum/read.php?FID=11&TID=9487
PANORAMIC PLANETS by CFandM
Although this is not the only one
Here is the link to this other in the filter library
http://filterforge.com/filters/10306.html
And this to the forum
http://filterforge.com/forum/read.php?FID=11&TID=9441
lipebianc
FFF = Filter Forge Fan
Amazing filters by CFandM and terrific examples by SpaceRay! smile:)
Thanks for your comment lipebianc, glad you like them smile:)
Thanks lipebianc and yep some good samples from SpaceRay...
Apart fr om the very well done and lovely and awesome filters fr om CFandM
There ALSO the real and original filter that has surely been used to make all the photos shown on the first post (because they have not travelled in time and got the CFandM filter and went back in time) and this is the:
SUB BLUE LITTLE PLANETS PIXEL BENDER FILTER
http://www.subblue.com/blog/2010/6/17/little_planets
Little planets are created by applying a stereographic projection to a spherical panorama.
Stereographic projection is a mapping that projects a sphere onto a plane
I think that the CFandM uses Polar coordinates effect instead of this Stereographic projection.
Although the main point is to build your own small planets as shown above (specially on first post) in this filter fr om SubBlue you can ALSO create the oppossite effect and warp the photo outward.
The best and wonderful thing on this filter is THAT ALL IS PREVIEWED, MADE AND RENDERED IN REALTIME - ZERO WAITING
Of course this is not a CFandM fault, and he have done a very good filter, but the problem is ON Filter Forge not having GPU acceleration.
The lim itation is that you can go beyond 4096 pixels inside the filter, BUT you can load slighty higher resolution of about 4500 pixels or perhaps up to 5000.
Many things have changed in 3 years after I made this thread, and now this photo creation technique is much more popular and there is much more software available to make this possible
The easiest ones are the new apps available for smartphone and tablets, specially for iOS.
Google search for Little planets app
There are also new software available for desktop computer but do not have now the links, will put later
33,799 Registered Users
15,373 Topics
11 unregistered users.
