Messages 1 - 45 of 59
| Posted: February 11, 2012 4:19 pm | ||
Great, excellent and very well done filter to make polar distortion in a very good and different way as is usual on Photoshop, much better with this one.
Not only can be used for making small planets also can be used to creat different kind of image compositions preparing carefully the source image and nothing else. |
| Posted: February 11, 2012 4:24 pm | ||
And one the variations available that gets a very good effect
For more examples, see this thread here http://www.filterforge.com/forum/read...5&TID=9300 |
| Posted: February 11, 2012 4:26 pm | ||
| Posted: February 11, 2012 4:37 pm | ||
| Posted: February 11, 2012 4:40 pm | ||
| Posted: February 11, 2012 4:42 pm | ||
| Posted: February 11, 2012 4:47 pm | ||
| Posted: February 11, 2012 4:52 pm | ||
| Posted: February 11, 2012 5:27 pm | ||
Very cool examples!
I like the last one the most, it's very special. |
| Posted: February 11, 2012 6:29 pm | ||
| Posted: February 11, 2012 7:52 pm | ||
| Posted: February 11, 2012 8:05 pm | ||
| Posted: February 11, 2012 8:06 pm | ||
| Posted: February 11, 2012 8:07 pm | ||
The sources photos for the Paint Splashes are this ones here in the same order as above
| Posted: February 11, 2012 8:19 pm | ||
| Posted: February 11, 2012 8:27 pm | ||
| Posted: February 11, 2012 8:35 pm | ||
| Posted: February 11, 2012 8:36 pm | ||
| Posted: February 11, 2012 8:39 pm | ||
| Posted: February 11, 2012 8:52 pm | ||
| Posted: February 12, 2012 3:01 am | ||
| Posted: February 12, 2012 3:06 am | ||
| Posted: February 12, 2012 3:15 am | ||
The Amethyst ball looks evil
Like something from an alien horror movie. |
| Posted: February 12, 2012 7:14 am | ||
lipebianc
Wow! Fantastic examples, SpaceRay!
"From the moment we are born, we start being filtered..." |
| Posted: February 12, 2012 1:06 pm | ||
| Posted: February 12, 2012 2:40 pm | ||
| Posted: February 12, 2012 2:41 pm | ||
| Posted: February 12, 2012 2:43 pm | ||
VERY IMPORTANT WHEN USING THIS FILTER
Please be aware that when using this filter is VERY IMPORTANT the orientation of the photo you are going to use !!! Look at the above concert photo, ALL is straight and have a horizontal layout, so with this kind of photos is the best ones to get the best from this filters. Also is the same for Skylines landscapes of cities. USE PHOTOS THAT ARE HORIZONTAL Like the concert above or also this examples
AVOID USING VERTICAL PHOTOS - ROTATE THEM TO HORIZONTAL TO USE You will get very bad results from VERTICAL oriented photos, and will not work right. Please if you have vertical photos, rotate them 90º to make them horizontal and then you can use this filter. NOT RECOMMENDED HORIZONTAL PHOTOS
| Posted: February 12, 2012 2:59 pm | ||
| Posted: February 12, 2012 3:04 pm | ||
As said above I had this source photo as a vertical photo originally, but then I rotated it and could be able to use it to create the above ring of fire, that would not be possible if the photo is not horizontal.
This excellent fire photo is taken from the very high quality and great photos found in the huge collection of www.cgtextures.com This one here is a composition collage I have made from 4 different photos joined toghether. Here is the original source photo |
| Posted: February 12, 2012 3:06 pm | ||
PROBLEM WITH THIS FILTER MAKING LONG HORIZONTAL PHOTOS ???
I have put ALSO this long fire image because I have seen that there is probably an error in calculation with this filter when using large horizontal photos as the one above of fire. Why I say this ? Because as you can see in the ring of fire above the center part is compressed and tight and does not follow the same conversion ratio as on the sides. Photoshop polar conversion makes it better (only in this kind of photos, on lots other is much worse than this filter) Here below is the result from Photoshop |
| Posted: February 12, 2012 3:23 pm | ||
lipebianc
SpaceRay: Thank you so much for the extra examples and very useful tips!
Impossible seeing all this and not being tempted to use this magnificent filter! ![]() "From the moment we are born, we start being filtered..." |
| Posted: February 12, 2012 3:35 pm | ||
BUT really I am cheating here
I mean that I added some more space to the original horizontal photo above as you can see in the screenshot here below SO this is the real image I have used to get good result on photoshop and NOT the original thin and long fire photo which gives bad result in photoshop too. |
| Posted: February 12, 2012 3:36 pm | ||
| Posted: February 12, 2012 3:40 pm | ||
BUT WAIT THIS IS NOT ALL !!!
If you go to the filter forge settings tab in this filter and put Profile=1 Size =0 Uncheck invert AND with these settings you will get something that is VERY SIMILAR to the Photoshop good result, BUT SURPRISINGLY MUCH SMALLER
I wonder WHY is this happening in this filter ? Please see the result here below |
| Posted: February 12, 2012 3:48 pm | ||
| Posted: February 12, 2012 4:14 pm | ||
| Posted: February 12, 2012 4:22 pm | ||
| Posted: February 12, 2012 4:31 pm | ||
| Posted: February 12, 2012 4:33 pm | ||
Thanks SpaceRay..Guess you like this filter then..
| Posted: February 12, 2012 7:22 pm | ||
But isn't it like free publicity to the stock companies?
| Posted: February 13, 2012 6:19 am | ||
Yes and No...
Then there is no image for that post or in some cases a blank spot with a "Image Not Found" or "Blah blah Company made us take this down Blah Blah"... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: February 13, 2012 8:04 am | ||
33,846 Registered Users
+13 new in 30 days!
+44 new in year!
