I want to show the other possible uses of this beautiful filter when you change the colors and replace them by photos.
This thread is totally inspired in the filter Ink Ghosts by Tim2501
Please see at the end more details about why I have made this
________________________________________________________________________________________________
In the thread of Please, any expert that want to optimize this filter for higher speed? Rod_D wrote:
Rod_D wrote:
You can try this one
I only renamed it to tell which is which.
And then fr om looking at the filter modification Rod_D made I got this idea
Thanks very much, this is much faster, although it does not give the same results but is still very good and give very nice effects.
I have had the idea also that WHY ONLY USE PLAIN COLORS ?
If the filters has two colors, why not change this colors into photo images ?
Well I have already done this and here you can see the results as I have added them to the filter as new presets
I only updated the name with the "Images", all the filter is exactly the same, only added presets.
Also you do not have to change BOTH colors into photo images, you can change just one and use the as plain normal color as tint colorizer of the photo.
As you can see for example here
And here is another example with the same red tint over another photo made previously with Filter Forge
Also you do not have to change to BOTH colors to TWO different photos, you can replace both colors with the SAME photo, and then you have the beautiful smoke effects over that one photo and arrange the smoke effects with the "Size, pixels" and "variations" sliders.
Here is one example
Also using just ONE photo for both colors and then change the focus setting to around 50 and the put smaller amounts in the "size pixels" slider you can get weird effects.
Here is one example
And with the same one as in the above post but changing the focus to 25 or 30 it will be like the invasion of the black ink over the photo smile:D
And with just ONE photo, focus at 50 and make the Size Pixels amount very small according to the maximum value available, you can get this weird effect shown here below
HERE IS THE FULL HISTORY OF THIS THREAD IF YOU WANT TO KNOW
This thread is totally inspired in the filter Ink Ghosts by Tim2501 and as you can see in the comments page of this filter it is VERY SLOW.
Then Morgantao wrote this thread Submission wizard speed limit
And this thread inspired to begin this other thread How this filter has passed through the SPEED LIM IT of submit wizard???
And the with the answer from GMM I started this other new thread Please, any expert that want to optimize this filter for higher speed?
I have done all this because this is a very good and beautiful filter and was a shame that it was so slow
I hope that we could contact the author and tell him about this and hope that he/she agrees with this.
I have made a new one with ONE photo replacing both colors and got this cloud landscape
33,801 Registered Users
+301 new in year!
15,373 Topics
16 unregistered users.
