I have seen this very good filter BUT is VERY SLOW and can ONLY be used at 600 x 600
Ink ghosts
http://filterforge.com/filters/10137.html
This ONLY works well for 600 x 600 , if you try to make a higher resolution it will take lots of time, and even HOURS to render the result.
GMM wrote:
I'm not an expert in filter construction so I may be totally incorrect here. But in my amateur opinion a high-detail Noise plugged into a Noise Distortion is a poor architecture. This filter speed may be significantly improved.
OK I´m a MUCH less expert than you, and also think that there is something wrong in this filter that is making it really go VERY SLOW
Please anyone that wants to optimize this filter and make a GOOD construction to get the same effect but faster?
Then it can be contacted the author for authorization.
Thanks very much
Well I see this like a little challenge. I hope the author's ok with me doing this smile;)
did seem a bit of a challenge so had a bit of quick crack at it, Skybase might achieve a better time/result though
on my machine original takes 29.48 sec - mod version takes 16.36 sec - there is a
there is a change from original look but not to drastic
Thanks Skybase and Carl for acepting the challenge smile:)
Very well done bringing the filter to HALF the time !! and only looses a bit of detail in the softer smokes, so not a drastic change as you said. Good.
Let´s see what Skybase can do
Nice job!
Do I hear 10 seconds? smile;)
It'll take a while before I can do something about it. I basically began just taking stuff apart and looked at it for a while just to see what can be done. Well turns out there's a lot of things that can help this filter bring its self the speed.
I gotta do my thesis work and it's kinda on the edge right now. I'll be working on something like this next week probably hehe.
Don´t worry, take the time you need and see what you can do.
If understans this well, this means that there are many possibilities that it can be fixed and make it faster. Good news.
Thanks very much for doing this and help
Rod_D
have you seen my eraser?
Filters: 3
You can try this one smile:)
I only renamed it to tell which is which.
Ink ghosts_RD.ffxml
Rod
Thanks very much, this is much faster, although it does not give the same results but is still very good and give very nice effects.
I have had the idea also that WHY ONLY USE PLAIN COLORS ?
If the filters has two colors, why not change this colors into photo images ?
Well I have already done this and here you can see the results as I have added them to the filter as new presets
I only updated the name with the "Images", all the filter is exactly the same, only added presets.
Ink ghosts_RD_images.ffxml
Here are the new presets preview I have done
Also you do not have to change BOTH colors into photo images, you can change just one and use the as plain normal color as tint colorizer of the photo.
As you can see for example here
And here is another example with the same red tint over another photo made previously with Filter Forge
Also you do not have to change to BOTH colors to TWO different photos, you can replace both colors with the SAME photo, and then you have the beautiful smoke effects over that one photo and arrange the smoke effects with the "Size, pixels" and "variations" sliders.
Here is one example
Also using just ONE photo for both colors and then change the focus setting to around 50 and the put smaller amounts in the "size pixels" slider you can get weird effects.
Here is one example
And with the same one as in the above post but changing the focus to 25 or 30 it will be like the invasion of the black ink over the photo smile:D
And with just ONE photo, focus at 50 and make the Size Pixels amount very small according to the maximum value available, you can get this weird effect shown here below
Rod_D
Filters: 3
Pretty cool idea to add images with colors.
I just hope the original author forgives us for tampering with his/her filter. smile:)
Rod
Thanks, glad you like the idea. I also suposse that the author forgives us for modifying and changing his filter, but the aim is to be able TO USE IT, as before was VERY SLOW.
I have also made this other thread to show what is possible to make with this filter adding photos
Ink Ghosts by Tim2501, Optimized by Rod_D and added Images options
the first 3 samples are a great effect adding pics smile8) , the bastardizing of poor Tim's filter is complete, I vote Spaceray tells him smile:D
If Tim's reading the forums, he already knows.
If he's not on the forum, I won't tell if you won't smile:D
33,849 Registered Users
+10 new in 30 days!
15,392 Topics
