uberzev wrote:
Anybody know which are the "heaviest" components?
1. SLOWEST: Image-based components (Blur, Motion Blur, Sharpen and High Pass) with any slow component (like Worley-based noise) as a source.
2. SLOW: Worley-based noises (any Noise except Perlin, which is very fast).
3. SLOW: Image-based components (see above) in general, because they need to prepare a source bitmap before rendering themselves.
4. CAN BE SLOW: Refraction, especially with a slow component as a source. Refraction takes 3 samples of the source input.
5. CAN BE SLOW: Any Noise (or any component based on Noise such as Noise Gradient, Noise Distortion or Noise Curve) with high Detail and Roughness (they are interdependent) especially with a custom curve as a profile.
6. CAN BE SLOW: Any Noise with a custom curve as a profile -- the curve is sampled once for each noise octave (for Details = 10 you have 10 samples of the curve per one noise sample).
5. CAN BE SLOW IN CERTAIN CASES: Any component that generates edges for anti-aliasing (Patterns, Worley noises, some of the adjustments). But since anti-aliasing is done in a separate pass, that shouldn't impact speed too much.
6. FAST: Patterns, Channels, Adjustments, Gradients (except for Noise gradient).
7. ULTRA-FAST: Externals (Image and Selection), Checker, Switch, Blend, Offset.
rilos
rilos
Filters: 9
Thats a good hint, thanks a lot!
regards, rilos
byRo
an Englishman in Brazil
Sometimes a filter may use the External Image as an input to many different components. Often the connections can cross the whole filter from start to end.
In this "ULTRA-FAST" case, can I interpret that we can sprinkle duplicates of the External Image throughout the filter without suffering any (or too much) delay. i.e. increased legibility, without sacrificing speed. smile;)
If so, is the same true of the other components quoted?
Rô
Yes, you can use multiple duplicates of the Image component, this won't affect the speed.
External > Selection.
As for other components, I would not recommend duplicating them. The renderer has an optimization called "sample cache" that can save you a significant amount of rendering time in situations when a single component has multiple outbound connections -- you won't get the speedup when using duplicates instead of connections.
byRo
Thank you, Vladimir.
Rô
Maybe these optimization tips should also go into the help wiki (I couldn't find them in the wiki anywhere). And how about a rendering knowledge-base with its own sub-section?
Torley
Second Lifer
Good tips to keep in mind! Thanx. smile:D
I'm enjoying using Filter Forge to create http://torley.com/textures
Great info!!! Thanx Vladimir smile:)
Can you elaborate on this?
A sample is a single evaluation of the image function (built by the filter tree) at given coordinates. To determine the surface normal vector, we need to know the surface heights of at least two more points near the location of the central sample. Hence, three samples.
Vladimir,
the average user probably won't be too familiar with the technicalities of sample-based architectures (and neither am I). Although there already is good info on this in the 'Result Component' Wiki entry, I sincerely hope to see a section that delves deeper into the topics of 'rendering', 'samples', the 'image function' and the 'filter tree', sort of a 'Filter Forge under the hood' article. smile:D
David S
Filters: 19
Obviously one would want to create the most efficient filter possible, so the User does not have to "wait for the paint to dry", but at times efficiency and creativity seem to be at the opposite ends of the spectrum. How long is too long, when it comes to rendering, for a filter to be accepted in the library?
We usually don't reject filters based on their rendering time, except for filters with absurdly long rendering time which blocks our rendering queue. You can look at the filters included with Filter Forge to get the idea of acceptable rendering time.
Carl had one rejected because of it.....I think it took 7 or 8 minutes to render.....
divi
Filters: 3
does extracting channels improve performance aswell? let's say you have a b/w noise and extract the lightness-channel and continue to perform whatever it is with that channel only - will this improve performance compared to using just the noiseoutput or is this approach useless because an empty hue and saturation channel dont cost performance anyway?
cheers
No, you will simply be processing R = G = B after that. However if you have different grayscale sources that will be processed exactly the same way, you can assemble them into a composite source (e.g. Assemble RGB), do your processing and extract the channels when needed seperately. That might speed up things a little.
Vlad is there a speed list for the new components, or can you update your first post - I seem to have taken a backward step with speed of V2 filters smile:)
Sure, I'll update the post after the release. For now, here's the quick info:
- Everything in the RGB Math category is very fast. Derivative is a bit slower due to two samples per incoming sample.
- All Transforms are very fast.
- Polygon, Ellipse and Rectangle (and their Free counterparts) are generally fast.
- Free Gradient is very fast, but the Relative Repeat continuation mode slows things down a bit.
- Both Bombers are fast, but watch the Density parameter, larger values can slow things down.
- Median/Minimum/Maximum can be slow on high Radius valyes, plus they're bitmap-based.
- Speed of Map Script and Curve Script, obviously, depends on what you write there. Compared to native components, scripts are slower due to Lua interpretation/execution overhead.
- HDRness doesn't make components slow, so new HDRized components should be as fast as their LDR counterparts and older versions.
Thanks, that's a help, the Median/Minimum/Maximum is my problem I think then smile:)
smoocherz
Hello Vladimir, I have been a Filter Forge user for some time now and have created many wonderful images with its help. However the "Speed" issue is a major concern to me. Might I suggest that you either create a new category based on speed or simply add a rating to each filter with a 1 - 10 scale so people like myself can avoid the ones that are just too time consuming.
I have a Dell Precision T3400 with an Intel Core2 Duo CPU E4500 @ 2.20 Ghz, # GB Ram, 32 Bit Operating System, NVidia 8500 GT Video Card.
I am open to getting a new PC that will be more effective and faster if y0ou can suggest any for a reasonable price.
Thank You for your time.
Regards,
David Kessler
That is an excellent idea!
I have a few comments/ideas for that.
First of all, since rendering now takes place clientside, we have many different systems, so the rating should be normalized somehow.
For that I suggest either a benchmark of the system that can be used as normalization factor, or a test rendering of a specific default filter that is used to measure the performance on a given system. This could be done the first time FF is installed or when the first filter is submitted.
When a filter is submitted and the preset rendering starts, an average tile rendering time is calculated. This average time is normalized with system bench value from earlier.
This should ensure a consistent measurement smile:)
inujima
I had been thinking that I could raise filter speed by making component composition simpler. but it was a misunderstanding.
In the above example, outputs of A and B are same results.
However, rendering time is greatly different.
Rendering time of A is 13.01 seconds, but B is 1.48 seconds.
I thought that the function of the offset component caches the value of a result temporarily, and if it would be called with same arguments at next time , the cached value is returned.
But...
In this example, rendering time of C is 4.30 seconds and D is 27.52 seconds.
Perhaps, in this case, the function of C is called seven times by calling one time the function of D.
However, like assumption of the previous example, if the function of the offset component has a cache, numbers of times of calling the function of C should be two.
I have not understood well about this structure. smile:?:
One more example.
In this example, added multiblend component which is same as C in the last example, and they are connected to each offset components.
Although this looks inefficient, the rendering time of E is 9.31 seconds.
It is 3 times faster than previous example.
Method of Increasing a speed of filters seems so complicated more than I had thought. smile:|
Very interesting inujima. thanks
Inujima, in the first example, what the heck makes B so much faster than A? smile:?:
If anything I would imagine ading another component would SLOW everything down a bit, not make it almost 9 times FASTER smile:!:
I know another way that it could help to increase the speed of filters, and this is that the FF developers team can make a new better and more optimized render engine for FF 4.0 and so all is supossed that would be faster. HINT HINT smile:D smile:D Do you listen FF Inc.?
Probably not smile:evil:
Looks like the sample cache mechanism is broken - I bet thats what the new 3.007 release is about.
Btw here is an informative discussion on the sample cache stuff..
inujima
The reason is that sample cache is working in B but is not working in A.
All the components may have sample cache function as Vladimir wrote at above link, but it is working only in limited situation.
The sample cache mechanism may be broken as Sphinx said, otherwise the system might have been changed. smile:?:
Regretably this has NOT been included in the 3.007 update, so we will have to wait until another update.
David S wrote:
Obviously one would want to create the most efficient filter possible, so the User does not have to "wait for the paint to dry", but at times efficiency and creativity seem to be at the opposite ends of the spectrum. How long is too long, when it comes to rendering ?
Good question, as how long is too long for waiting for a filter to render the result so the User does not have to "wait for the paint to dry" and I agree that we want to make the most efficient filter possible but for creative and innovative filters are many times complex and with lots of components, so it depends on the FF render engine speed to process all of them to offer the final result.
Again with the question, How long is too long for you ? How much can you wait for a result you want and need ?
Yep, there's no magic number on how long is too long. It totaly depends on the user and how much he wants the result a filter gives.
What happens with the Smudge component?
Is it considered fast or slow?
I have read all that Vladimir have put in both of the list he has made and the smudge is not included.
I'd say smudge is like "medium speed" it can run pretty darn fast at the same time pretty darn slow depending on the way you deal with it.
The list here is from FF1.0 you won't see many of the newer components present.
Thanks, but then when would it run slow, what you are refering when say "depending what you deal with it" is it that when you try do those 3D things some of you make?
Oh Yes, is true, that this is very old, so there can´t be any of the newer components
For example if you enable Anti-Alias it'll run slow as you'd expect. Disabling orthogonal and having density at 100 will make it sluggish. Pretty sure there are a couple more, but those settings alone are a mild hinderance to render speed. So I guess it's "can be slow".
Thanks for the tips on the smudge settings that can make it slower, will have to test it with time benchmarks to see how much slow is it.
Velho
Velho
Filters: 6
I made a test to see which line creation method is the fastest: Line draw benchmark
I'd be interested to see if anyone can improve them.
Leo Fernevak
Leo Fernevak
Filters: 14
Velho,
Good work and interesting to see different methods.
For a few months I have experimented with a set of scripts I have made which draws lines and shapes using a string table. My scripts can draw 1000 filled random trapezoids (tetragons with variable upper and lower x-coordinates) under 1 second. The main problem I have had is that I have never been able to use the Anti-Aliasing function with sucess within any script. Probably, the AA function needs some revision, which is why my results with string table drawing are a little bit pixelated.
The benefit of drawing shapes into a string table is that you draw everything you need before the 'get_sample' function. The 'get_sample' function simply checks the 'pixels' in the string table, where all shapes have already been drawn. Also, you can add fast shading possibilities within the 'get_sample' function, using Lua commands for searching strings for a particular character. In this way, you can easily calculate the horizontal center of shapes and add a shading based on the range from center to edge.
Here are two filters I have made using my string table drawing method:
GM Techno Shapes
http://filterforge.com/filters/11670.html
GM Photo Windows
http://filterforge.com/filters/11697.html
Velho
Velho
Filters: 6
GalaxyMeridian,
I've checked the Techno Shapes filter earlier, you certainly have made an effort with the script. Thanks for reminding about the pre-rendering method.
One possible thing for me to test is to pre-render one horizontal "slice" of a vertical gradient, then rotate and shift it to correct position. I don't have high hopes about it, but it could be worth a try.
xirja
Idididoll Forcabbage
Regarding Blur and Smudge, there is an exception to #1:
"1. SLOWEST: Image-based components (Blur, Motion Blur, Sharpen and High Pass) with any slow component (like Worley-based noise) as a source."
which is, in the case when using a blur or smudge with minimal settings, it can:
a. reduce the time for anti-aliasing passes
b. act as a buffer (there is no recalculation to upstream unchanged components)
c. mysteriously speed up image transformations: see last attachment: Image Bug Solved_.ffxml
So Blur and Smudge can both speed up and slow down a filter depending on the settings.
33,820 Registered Users
+14 new in 30 days!
+17 new in 30 days!
15,381 Topics
25 unregistered users.
