| Velho | ||||
| Posted: October 28, 2013 3:02 am | ||||
| Velho |
Just to clarify: these methods are for drawing a line from point A to point B.
Demonstrating line drawing methods: 1: rectangle, line ends masked 2: rectangle, line ends masked & rounded ends 3: rectangle, no masking, continuous 4: rectangle, no masking, scaled to length 5: polygon, line ends masked 6: gradient, rotated, line ends masked 7: gradient (line width varies, not worth fixing) 8: script by ThreeDee 9: script by Velho 10: RGB math components Benchmark: -image size 600x600 pixels -500 iterations -blend mode lighten (#6) -anti alias off -start X/Y: 50/50 Render time 1: 1min 6s 2: 1min 21s 3: 1min 19s 4: 2min 21s 5: 1min 3s 6: 1min 38s 7: 1min 33s 8: 5min 30s 9: 5min 22s 10: 3min 46s System: Intel i7-3770K 3.50GHz Recommendations Fast lines: method 1 (easier to use than polygon, has bevel) Lines with rounded ends: method 2 Lines with gradients or patterns: method 4 ---------------------------------------------------- There is one method missing, drawing a line with linear curves and gradients. This method got quite messy form the start, so I omitted it. It's possible to use this method, though I found it not very useful. I made a simpler line with a gradient, it's as fast as the rectangle method. The line thickness varies, though (could be fixed, but with a cost). Explained: |
| Posted: October 28, 2013 3:13 am | ||||
| Velho | ||||
| Posted: October 28, 2013 3:17 am | ||||
| Velho | ||||
| Posted: October 28, 2013 3:18 am | ||||
Coolness. This will come in handy for a number of things!
Very interesting first example, looks like a close-up photo of a flower. |
| Posted: October 28, 2013 8:23 am | ||||
Very good, interesting and cool, will see how it works and then will do the benchmark that you have suggested
| Posted: October 28, 2013 7:59 pm | ||||
| Velho |
No, sorry, I suggested improving the methods. Although, I'd be interested to see the rendering time of the first method on slower computers. |
| Posted: October 29, 2013 2:30 am | ||||
I always think gradients and thresholds are ridiculously fast compared to polygon components in general. Translate components can also add to render times. The stuff we did back in 1.0 where we'd use offsets to do most of the translation seemed ridiculously fast compared to how we do it in versions beyond 1.0. Just that stuff's more convenient.
| Posted: October 29, 2013 4:02 am | ||||
| Velho |
By the way, since the RGB math components accept different values for each channel, you can draw four separate lines at the same time. I did a quick test with RGB channels, but the overhead from the channel extract and assemble components inflated the render time to 11 minutes (200 iterations).
| Posted: October 29, 2013 4:27 am | ||||
I want to thanks again very much for this filter to benchmark what would be the fastest way to be able to use for drawing a line from point A to point B
Is curious and interesting that using a script for this is 5 times slower than other ways and they are the slowest option at the bottom of the benchmark The list in the first post above or in the About tab is not ordered according to the fastest one, so I have reorganized it BENCHMARK LIST ACCORDING TO THE FASTEST OPTION The first number at the left is the "Line Drawing Method" number in Settings tab or inside filter editor 5: 1min 3s polygon, line ends masked 1: 1min 6s rectangle, line ends masked 3: 1min 19s rectangle, no masking, continuous 2: 1min 21s rectangle, line ends masked & rounded ends 7: 1min 33s gradient (line width varies, not worth fixing) 6: 1min 38s gradient, rotated, line ends masked 4: 2min 21s rectangle, no masking, scaled to length 10: 3min 46s RGB math components 9: 5min 22s script by Velho 8: 5min 30s script by ThreeDee have also made a new thread about this topic 10 different methods for drawing a line in FF from point A to point B |
| Posted: November 17, 2020 6:14 pm | ||||
33,846 Registered Users
+13 new in 30 days!
+13 new in 30 days!
+44 new in year!
33 unregistered users.
