I think that the topic of simulating ( or faking) real shadows according to a light source inside Filter Forge is a very good and interesting thing, and useful for many projects and things that could be done, and this makes a great difference in some filters that can benefit from this, from having or not this shadow effects, please see the examples shown below in the examples part so you can see the difference.
I would like to research more and learn more about this topic and that this thread can be a source for others interested in this topic, and I am making a thread compilation
NOTE: This thread would be better if it was in the FF wiki instead, and I want to put it there, but I am sorry that I still have not learn how to do it and the editing is done in a different way than the forum
POST MADE IN 5 PARTS
1 - There are 3 different shadows styles
2 - Compilation of threads in the forum I have found about about shadows
3 - Filters already available in the FF library for you to use and experiment, and also you can see how they are built
4 - Filters I have found that uses shadows
5 - Examples showing the shadows effect and how it looks
THREE DIFFERENT SHADOWS STYLES
As far as I know when looking at all the shadow filters that I have seen I could see that there are 3 different shadows styles
1 - Simple Drop Shadow (that does not matter the height)
2 - Simulating Real Shadow lighting using height information but without using Surface filter (no lighting tab)
3 - Simulating Real shadow lighting using height information with surface filter (Using the Lighting tab and have also AO (Ambient Occlusion)
Here is explained each one in more detail and with an example
1 - Simple Drop Shadows (that does not matter the height)
This is the most simple and easy one, and is used to simulate a shadow to appear under the object or shape so this makes a separation between the top and lower objects and makes the image deeper and as if it was in different layers
An example of this is done on my own
Simple drop shadows by SpaceRay
2 -Simulating Real Shadow lighting using height information but without using Surface filter (no lighting tab)
Here is a more complex shadows and is more realistic as it will take the height information available and will use that to make shadow projection
The best example of this is done in this filter
Fast cast shadows or Blast Shadows by ThreeDee
This is better than the second one as you will have more control and be able to use also the lighting tab and also have available the AO
The best example of this is with this filter
Hard Shadows filter snippet by Jitspoe
COMPILATION OF THREADS ABOUT SHADOWS IN FF
In some (or most) of these threads there are inside filter examples for you to try and experiment and learn more about this topic
Shadows play by Betis and others
_______________________________________________
This very well done and easy to use shadows technique made by ThreeDee
Another very well done technique made by Jitspoe also easy to use in your filter and there is also more information on the comments
Also this thread from 2006 that is also interesting and good now started by Crapadilla
New Processing Components: Illumination, Shadow, Reflect
Sphinx Shader v0.2 (alternative shader)
Sphinxmorpher
An attempt to create a custom shader/ligtning system. It is not meant to be a ready to use filter, but rather an alternative to the build in surface mode result module.
Basic Shadow by CFandM
There are a lot of filters with shadows to look at. This is just a shadow snippet or a how to sort of filter.
Shadows thead asking Vladimir Golovin by Jitspoe
Using GPU for Shadow?
Shadows started by Jitspoe
'Directional Shading'
How to make Shading from bump channel?
Wow: I'm thoroghly impressed ThreeDee... that's very impressive
Shading Any shape started by James
In this thread there are two filter snippets
Script based shadow by ThreeDee ?
Script-component-based filter ideas
How about cast shadows from a height map?
FILTERS AVAILABLE IN THE FF LIBRARY FOR SHADOWS
Hard Shadows by Jitspoe
Cast Shadows by Jim Niehues
Illumination/Shadow by Crapadilla
Topdown dropshadow by Totte
Sphinx Shader v0.2 (alternative shader) by Sphinxmorpher
I have made a simple snippet for making simple drop shadows and then Skybase has made a better or alternative version available in the comments page
FILTERS AVAILABLE THAT USE SHADOWS INSIDE
Cube Wall by ThreeDee
Polygon Fill by ThreeDee
_T_Rain Drops Hard Shadow by MathOrWhat
CUT IT OUT !!! by Carl
pile of stones by Totte
Float On by garbanzo
Ball Pit by Morgantao
Checkered Racing Flag (triangular) by jffe
The Ripper Modified by Bill DeBekker
Photoweave 2 grids of stripes by SpaceRay
EXAMPLES SHOWING THE SHADOW EFFECT IN FF
Here below I have used my simple drop shadow to make a great difference that is shown in this thread
Fractals by Bomber
This shown here is the normal filter version without any shadow, and for me this is not good because all the layers looks like they are "glued" together and there is no separation between them and looks too flat
I think looks much better than the above one here and you can see the real layers and it looks more deep and better
In the same way this other example
This one above is too much plain and can´t really see well the different elements, so let´s give shadows that make it pop.
Which one do you think looks better from this two ? For me is clear that this second one with shadows
Here is a more complex lighting and shadow made by Threedee
Using the built-in preview images as reflection environments
Lights, shadows, reflection are all from gradients, refractions, blast shadows, etc.
More information and examples are here in this thread
Other Interesting Ideas by ThreeDee
From Betis this other very good and well done example
shown in this thread --> The Disquisitions of Betis
And also from Betis, this other Lego bricks simulating real shadows
This is found in this other thread on page 15 at the top
LAB#3015 Skybase
I put back this thread if anyone else is interested in making shadows for filters and want to have the information I have found here, at least until September 2013, there can be new and different ways to make shadows since that date, so anyone is free to update and put additional ways to make shadows in FF
Hi SpaceRay,
Thanks for the compilation. I didn't see the Derivative Component method mentioned (maybe it was). That is the fastest shadow creation method from height maps.
Thanks ThreeDee, and good to know from an expert what may be the best and fastest way to add shadows
If anyone else knows any other possible way to simulate shadows in FF, of course is free to add it here.
Hello again, I started this thread in 2013 and I wonder if in 2017 with FF 6.0 and the new FF 7.0 beta there could be possibly any additional new ways to add shadows that could be faster than any of the previous ways already done.
Do you know if in all this time from experimenting and testing anyone have made or discovered a new way to do it?
Do you know any filter not shown here that may include an interesting and cool way to add shadows that is not included in this thread?
In 2014 I made also this thread
Best way to add shadows to Bomber result? Making shadows without blur?
How was done the shadows made by Sphynx shown here? Is it using some kind of depth map? as it looks that is a progressive depth shadow
( the example comes from this thread here)
And another reason is to find the best way to add shadows without using blur to this awesome filter from Ramlyn
Scratched Rectanglex by Ramlyn
Bummer answer, honestly not really. 7.0 did bring some pretty major changes to how we can make stuff but in the end the old traditional methods still stand firm. I would argue that it hasn't really changed albeit it might be slightly easier in 7.0 but I can't say for certain what.
For kicks there's a shadow-generating group in my filter PaperCrafts: https://filterforge.com/filters/13031.html
What I would say is that I think the way we make shadows in FilterForge differs based on what kind of input is available. For example, my Paper Crafts filter requires two gray-scale inputs to produce a clean effect it otherwise doesn't work. Betis shade utilizes a very similar input albeit his work is way more sophisticated than what I did for PaperCrafts which results in extremely reasonable output as you see in the picts above. So keep in mind that this is kinda relative to each of its own filter.
Thanks very much for your interesting and helpful answer Skybase.
Yes, I agree that making shadows will depend on what you are using (shapes, images, polygons....) and what components you are using that have different kind of inputs.
Will see how you Papercraft filter works and how it is done, thanks
Depth shading, depth height map and crude ambient occlusion.
Depth Shadow.ffxml
I have found new shadow ways using loops that seems interesting. Do not know if these may be faster or better than any of the above
Loop shadows with layers by Truman
Fake point shadows for black and white source images.Three layers version of “Loop shadows” filter
Loop Shadows by Truman
I don't know if it's relevant, but I was doing phake shadows in V1 since using the lighting components takes too long on my computer ha-ha. Might be interesting to combine techniques.
https://www.filterforge.com/filters/10326.html
https://www.filterforge.com/filters/10087.html
Yes, is relevant, because is about a way to do shadows, so is good, will see it how is done. Thanks for showing your filters.
