Hape
Hape
a filter with the PIN-UP effect would be cool
greeting
Hape
http://henning.deviantart.com/art/Bat...2-46834532
Please, what do you mean with the "pin-up effect"
In the image I can´t really see what you mean.
Would be good if you could explain it more
Hape
Hape
There is a photo of a painting effect
Tutorial
There might be some in the library that has this look but I do not remember off hand...But I'll see what I can do with it..Looks like it might be fun.. smile:)
Just gotta find a good image to use for testing.. smile:)
Mongoose King
Mongoose King
Filters: 21
That's not a great example as it is itself a modern recreation of a pin up done with photoshop.
Pinup are usually posters of airbrush paintings based on photos, so it's a kind of soft focus plus posterize. Also, the colour is usually more vivid.
Here's a good page showing pinups and the photos they are based on.
http://ulkacurl.livejournal.com/212899.html
Release the Mongoose!
That was exactly what I was looking for MK... smile:) I did find some but that link is much better then some examples that I found...Originals and not re-creations.. smile:)
Heres a starting point...
Pin Up Girl.ffxml
Hape
Hape
yes is very good smile:)
Here it is again...This one is updated and I think ready to submit.Let me know how it works for you....This is the pin-ups that are re-printed and not original which is another filter altogether.....
Pin Up Girl 2.ffxml
Very well done, cool effect CFandM done with version 1
Hape
Hape
it looks pretty good but something is still missing, what is your opinion?
Perhaps it needs more contrast or sharpening?
As it looks like soft blured, and in the link by Mongoose King they look sharp.
Mongoose King
Mongoose King
Filters: 21
Hmmm, seems a bit 'glowy' to me when you use it on that image, not quite right, doesn't look like a printed poster to me.
Mongoose King
Mongoose King
Filters: 21
Had a ponder and what I think the thing is, they seem to have sharp edges, but soft within the edges.
Has anyone had a play with smart blur or surface blur in photoshop? that's the kind of effect needed.. sort of. ..
Maybe using edge detect to stop area bleeding into each other at the edge during blur somehow..
Guess I'll need to do some more work.. smile;) smile:) Thats the trouble sometimes on some filters, it looks good with one image then on another image it does not look so good...Some of the images that I was using for tests looked really good. They also had a white background...So back to the drawing board.. smile:)
Well there are just some Photoshop tutorials that cannot be accomplished in Filter Forge...There are always some missing elements between the two...With this filter the missing element is some image adjustments that need to be made before even applying the effect...I am trying to work those out......Here are some samples of before and after the effect is applied...Not all images work so I have to find a happy medium that will work...
Hape
Hape
That looks really quite good. smile:) Have they made ​​with the PIN-UP filter?
I'll try it with other images
Nice examples there CF! smile8)
Too bad that, as you say, sometimes it works wonders on the images you try, and then not so well with others. Maybe add a few controls to make it more customizebale for different input images.
Hape Wrote..
That looks really quite good. Have they made ​​with the PIN-UP filter?
Yep they were processed with the attached updated Pin-Up filter...Some images work good and then others need something else before adding the effect..Still working on that...
Thanks Morgantao..Yep...
Pin Up Girl 2.ffxml
I'll probably finish up this filter on the weekend and submit it ...I still cannot get it to work correctly with that image Hape...It may be to dark of a skin tone to process correctly...I now have split some channels for editing with curves..Another example if the image is set-up before hand...
DOH! CF, your examples look above and beyond my expectations, but for some reason I can't find images that work "as advertized"...
You make it look so easy smile:|
hehe Thanks Morgantao..It looks like this is going to be a specific type of image filter...Kinda like the anaglyph filters..Even in that link to the tutorial that Hape posted these are the images that are used.....
http://de.dreamstime.com/stockbilder-...ge17501634
Right click to download, these are watermarked but at least you can still play with them.. smile;) smile:)
Heres the filter again...I took out the seperate channels part..It was not working that great so I just left it out.....
Pin Up Girl 3.ffxml
looking good smile:)
Hape
Hape
woooow ..... I compliment the looks very good indeed
33,814 Registered Users
+13 new in 30 days!
+27 new in 30 days!
