Colorblast
Colorblast
Hi, I have so many filters now that drilling down through them can be time consuming. I'd like to be able to somehow regroup all the filters into my own custom groups, for example: B&W, Painting Effects, Color Toning, Simple Frames, Complex Frames, Diffusion Effects, Old Effects, etc, etc. If not custom categories, then allow some kind of key word tagging so I can isolate exactly what I'm looking for. This would be outstanding. Cheers.
Wait a few days and FFCat will be released and will let you do exactly that.
It's freeware, open code, portable.
Here's a preview of how it works (Note that the video is of an early version, FFCat is much better now):
http://www.youtube.com/watch?v=eJuv6LUOc5M
Colorblast
Colorblast
Fantastic! That's exactly what I'm looking for. There is one problem though. Say I create a B&W folder with assigned filters to it, and then want to see those particular B&W filters previewed over my photo in succession of each other as the program lets you do now. Will the catlog perform this way, or will I have to note which filetrs are the B&W ones and then find them again in FF to preview over my working image? The catalog is certainly needed though. Can't wait for it.
Double clicking a filter will open it in FilterForge, so you can watch the results in succession by going down the list of filters.
For more details on what's in FFCat, take a look at the following threads:
http://www.filterforge.com/forum/read...#nav_start
and http://www.filterforge.com/forum/read...5&TID=9806.
Note that the latest and greatest version is not online yet, but it will be soon. smile:)
Morgantao wrote:
Here's a summery of what the tool can do now:
* create your own categories (folders)
* add as many filters as you want to a category
* add a filter to multiple categories
* add custom keywords to filter
* rate filters 1 to 5
* search filters by name\author\default keywords\your keywords\description
* arrange order of categories (move up\down)
* rename categories
* delete categories
* remove filter from categories
* delete a filter from the catalog
* sort filters by library ID\author\filter name\rating
* double click filter to open in FF
* see 9 default presets of the filter (Like online library)
* filters in list are thumbnailed
* see presets of your own (offline) filters
* images are cached for faster preview
* drag a filter from your disk into FFCat to add it to the catalog
* drag a folder from your disk into FFCat to add all filters in it to catalog
* see ALL filters
* see ONLY UNCATEGORIZED filters
* see filters in current category
Please leave all comments by monday, that's the estimated release date.
Thanks!
Colorblast
Colorblast
Hi Guys, just curious for an update on when we can expect FFCat to be released?
Cheers.
It's gonna be just a few more days. Maybe around a week. Should be before the end of the month. Definitly before the end of next month. smile:D
it MAY be available in MAY smile;) smile:D
Although reading this it is not true smile:D
Thanks for the update and the news I am waiting for the new upcoming era of using filter forge in a much better and new way much better than is possible now thanks to you FFCat
Colorblast
Colorblast
Hi All, any update on when FFCat will be available to use or play with? Cheers.
It's already available for a few months...
Check out FFCat is out of beta thread, or just dowload it from http://sites.google.com/site/morgantaos/FFCat.rar
Colorblast
Colorblast
Very good program, Morgantao. I'm curiuous though; is it possible for the program to install the filters as per their assigned default categories so I can skim through them as I would in FF. Eg. frames, Photo, Patterns etc etc.? This would save large time by playing within the group I'm initially looking for. Also, will it be possible to later view my test photo within FFCat so I can see which filter works best rather than flicking betweenFF and FFCat? Just interested to know your thoughts. Cheers.
Unfortunatly, the answer to both your questions is no.
FFCat is a tool that reads some of the information that is written into the filter file (.ffxml file). The default categories are not written in the filter, they are determined by FF's online library.
As for test images, FFCat does not render anything, it just extracts info from the onine library and FF's cache. If you double click a filter inside FFCat, it will open in FF. You only need to load your test photo once in FF, and each filter you double click in FFCat will open with that same photo in FF.
