Nebukadnezar
A minor annoyance about the steps curve: Is there a reason, why the first and last step are halved? More often than not an even distribution would be more helpful.
I can adjust it with start/end, but that's a bit cumbersome.
A bonus would be a check box to start with the first step and end with one before the maximum.
Also having more smoothing options would be nice.
Use the "threshold" to slide shift the curve forward or backward. smile;) So then the steps can start at the end or at the beginning.
Nebukadnezar
Thx, I surely must have played with that, even if I can't remember it. smile:D
Still it will either omit 0 or 1, if I haven't overlooked something else.
I ended up using a kludge once more. I attached the snippet, so you can check it out if you want.
Would be a lot easier, though, if one could wire controls and inputs directly with math.
Evenly spaced steps.ffxml
Nebukadnezar
Of course I was talking about "Stairs" all the time, not steps. -.-'
smile:( Awww!
And I thought we were going dancing smile:D
Nebukadnezar
Well, that looks kind of problematic, too. smile;)
+12 new in 30 days!
