inujima
HDR map input to Origin X and Y Input of Free Ellipse Component is invalidated.
I don't think its a bug but its more to do with the color...Not to advertise but I go through this in that guide I am working on... smile;) smile:D
.....The bottom eclipse is being controlled by the Controller.....The top is being controlled by the color fr om the Abs component...Then that color is controlled by the Value Controller.....Now when connecting a Value Control to a component that is color based 0 will produce black and 1 will produce white. Anything above 1 it will remain white and anything below 0 it remains black....So if you are trying to move that eclipse any further it will not move..The offset has reached its lim it in movement because the color is white....Here it is with the gradients....
Then the controls under 0 and over 1.....
inujima
No, this is bug.
Actually, HDR map works normally at Free Polygon component.
inujima
It looks working correctly at other components except Free Ellipse.
I see what you are saying now....The other components still move but the Free Ellipse stays still at that certain point.... smile:?:
Inujima, I love your black and white image at the bottom. If you want, it would be nice to create a filter with this effect. smile:)
Some hardcore bug! Nice find!
Should be fixed in the next program update.
+12 new in 30 days!
