xirja
Idididoll Forcabbage
Trying to sort a gradient based on perceptual brightness and then selecting the darkest color.
The script included in the attachment does not give the expected result. Getting values from
the associative table doesn't seem to be working properly, as dark blue should be the result.
Most likely there is a problem with getting values from the table after the sort. a nil issue?
Any other ideas on how to use perceptual(Lab L) values to sort/reorder colors?
GradientTestDark.ffxml
try this replacement:
Code
function get_sample(x, y)
   local c = {}
   for i = 1, 4 do
      c[i] = {}
      c[i].li = get_sample_grayscale(x, y, _G["I"..i])
      c[i].r,c[i].g,c[i].b,c[i].a = get_sample_map(x, y, _G["C"..i])
   end;
   local function compare(a,b)
      return (a.li < b.li)
   end
   table.sort(c, compare)
   return c[1].r, c[1].g, c[1].b, c[1].a
end;
xirja
Oh great, that _G["I"..i ] for multiple inputs! Thank you! It works, and much more elegantly than my baseball glove hands approach. smile:D
If there was a more general case of sorting a spectrum using OUTPUT_WIDTH though?
SpectrumTestCode.ffxml
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
