Strange things happen in 3.006 - I'm sorry I can't be more specific - I simply can't find any pattern to it. It is related to bad floating point numbers though..
I did send you a mail about this already - no answers.. Take a look at the attached filter - open the editor, find the Extract HSB that goes to a Tone Curve ("TC") - now try connecting the TC to the Blend that the HSB goes to.. I dropped a checkbox nearby with the text ("Connect TC to Blend!"). This causes strange things to happen to the result.. Fast Collage.ffxml Njyldgarkn sample cache! |
| Posted: November 28, 2011 5:06 am | ||||
Before problem shows:![]() Njyldgarkn sample cache! |
| Posted: November 28, 2011 5:10 am | ||||
After problem shows:![]() Njyldgarkn sample cache! |
| Posted: November 28, 2011 5:11 am | ||||
And some strange FP values..![]() Njyldgarkn sample cache! |
| Posted: November 28, 2011 5:12 am | ||||
The bomber might be the culprit here, because it has been involved in all encounters of this strange problem; the error just never shows immediately after the bomber.. Njyldgarkn sample cache! |
| Posted: November 28, 2011 5:14 am | ||||
Another buggy screenshot, notice the blend settings :-S While very annoying, this one does create a rather interesting output ![]() Njyldgarkn sample cache! |
| Posted: November 28, 2011 8:55 am | ||||
| uglyboys |
one problem or suggestion in filter.
though we increase repeat the image scale almost remains constant saurabh.gayali@gmail.com |
| Posted: December 7, 2011 11:50 am | ||||
| BenBeckwith |
Man I've been running into these issues all week and just came by to post about it, so I'm glad to see this.
Here's a simple test case I found that shows weird results. Bomber Blend Bug.ffxml |
| Posted: December 15, 2011 10:11 pm | ||||
| BenBeckwith |
And here's an image. The only part that isn't default is the last blend biased 100% to the high pass input in order to show the undesired effect. If you bypass the first blend then all works well. If you make a copy of the bomber and make it so one goes into the blend and the other into the high pass then it will also work fine. So it's just very weird, but hopefully that helps narrow it. |
| Posted: December 15, 2011 10:20 pm | ||||
This is very annoying - but even more so is that FF has not responded at all - I contacted them by e-mail also. Njyldgarkn sample cache! |
| Posted: December 16, 2011 10:56 am | ||||
Posts: 1759 |
This looks like another manifestation of the Subtle Bomber Bug (case 1, case 2, case 3). Dmitry aka Egret claims he has fixed the bug – please wait for the next program update |
| Posted: January 30, 2012 8:12 am | ||||
Mardar
This is great news. I was working on another filter last night and again noticed weird markings in the bomber preview but they didn't show up in the final result. So I was hoping this could be resolved soon. |
| Posted: January 30, 2012 8:58 am | ||||
This was in 3.006 and now we are in 3.008, and I do not know if this has been fixed yet or not, anyone knows? Thanks |
| Posted: June 4, 2012 2:24 pm | ||||
It has been fixed (tested in 3.008, probably fixed in 3.007) Njyldgarkn sample cache! |
| Posted: June 7, 2012 10:48 am | ||||
15,510 Registered Users
+7 new last day!
+52 new last day!
10,191 Topics
+10 new last day!
