Jsperl
Both standalone and as a plugin (PS CS4). It used to work fine, but I hadn't used it in some time, and now it crashes every time I try to launch it. If it helps, the last selected filter is "Van Gogh Flow".
Here is the bug report (from plugin launch):
Operating system: Mac OS 10.5.8
Physical memory: 4096 MB
Number of processors: 2, available: 2
Processor info: Intel® Core™2 Duo CPU P8600 @ 2.40GHz, ~2385 MHz
Filter Forge universal 2.012.22491.45506 Release-10.5, November 03, 2011 08:46 [Mon Nov 28 01:03:55 2011 -0800]
Bundle path: /Applications/Filter Forge 2/Filter Forge.app
Critical exception occured at thread 0xb04ba000 'RenderingMgr 0x19ad800/1':
<XFW::Exception> Application encountered an unrecoverable critical error and will be terminated.
Critical exception call location:
__gxx_personality_v0 + 1108 at 0x96dbc10c in libstdc++.6.dylib
std::terminate() + 29 at 0x96dbc14b in libstdc++.6.dylib
__cxa_rethrow + 79 at 0x96dbc2b1 in libstdc++.6.dylib
<unknown function> + 0 at 0x005d7f80 in Filter Forge
<unknown function> + 0 at 0x005d806d in Filter Forge
<unknown function> + 0 at 0x005d2482 in Filter Forge
<unknown function> + 0 at 0x00322cf3 in Filter Forge
<unknown function> + 0 at 0x0032e21e in Filter Forge
<unknown function> + 0 at 0x00323130 in Filter Forge
<unknown function> + 0 at 0x0031eb91 in Filter Forge
<unknown function> + 0 at 0x0032260b in Filter Forge
<unknown function> + 0 at 0x00323452 in Filter Forge
<unknown function> + 0 at 0x0031ec05 in Filter Forge
<unknown function> + 0 at 0x005d4fce in Filter Forge
<unknown function> + 0 at 0x005e214c in Filter Forge
<unknown function> + 0 at 0x0057d73a in Filter Forge
Possible original exception location:
<unknown function> + 0 at 0x00843077 in Filter Forge
<unknown function> + 0 at 0x0076c099 in Filter Forge
<unknown function> + 0 at 0x0076c8ea in Filter Forge
<unknown function> + 0 at 0x0076cfff in Filter Forge
<unknown function> + 0 at 0x0076d3fa in Filter Forge
<unknown function> + 0 at 0x0079118c in Filter Forge
<unknown function> + 0 at 0x0057d618 in Filter Forge
<unknown function> + 0 at 0x005b024d in Filter Forge
<unknown function> + 0 at 0x005983e6 in Filter Forge
<unknown function> + 0 at 0x0058ea9a in Filter Forge
<unknown function> + 0 at 0x0058f557 in Filter Forge
<unknown function> + 0 at 0x0058f9b4 in Filter Forge
<unknown function> + 0 at 0x005a15bf in Filter Forge
<unknown function> + 0 at 0x00843412 in Filter Forge
<unknown function> + 0 at 0x005a17dc in Filter Forge
<unknown function> + 0 at 0x00823249 in Filter Forge
<unknown function> + 0 at 0x008238d5 in Filter Forge
<unknown function> + 0 at 0x0084d012 in Filter Forge
_pthread_start + 321 at 0x96f8b055 in libSystem.B.dylib
thread_start + 34 at 0x96f8af12 in libSystem.B.dylib
Jsperl
Ok it seems that "Van Gogh Flow" might have been the cause of the crashing. Fortunately I was able to switch filters using the "Open in Filter Forge" feature on your web site and that seems to have solved the issue.
Unfortunately the Van Gogh filter is known to crash Filter forge under Mac OS.
olderdog
Mr.Joseph Chapman
This looked like a really neat filter, but unfortunately it's crashed repeated and now has completely screwed up loading of Filter Forge on my iMac Quad with 16gb of member.
I see this filter has been problem before. I'm aware of the LUA problem which isn't really the writer's problem. But this filter ought to be flagged as death on Macs. Nothing quite that dramatic, but a warning that it is likely to cause crashes on Macs. At this point, I'm trying to sort out removal.
I think the moderator has the right language. "Unfortunately the Van Gogh filter is known to crash Filter forge under Mac OS." I would not have downloaded it had there been a warning like that.
jmc56
olderdog
Mr.Joseph Chapman
Thanks to a user named Inujima my FF can at least load without Van Gogh crashing it. He's posted a link on another thread which allows use of the filter on Macs without crashing.
http://www.filterforge.com/upload/for...ript.ffxml
jmc56
sherif
I am having the same problem and i tried uninstall and re-install, nothing work. I tried olderdog link and it does not work. All i need is to work without Van gogh. Helppppppppppppppp
sherif
GMM moderator,
Pls tell us what to do to either delete this filter or get our FF working. We bought the FF and we need to use becasue of how beautifull it is and such shame that you keep such filter that ruins everything. Pls help us.
sherif
I figured out how to solve it. Unfortuanetly by deleting the filter itself. The way to do it is when it prompts to report the bug accept and select reopen. The problem will still be there but don't click anyway except on the tool bar. Select filter>locate filter> drag it to the trash and the software will work.
Try it and hope it work with you, it did with me.
sherif, you can delete the filter that is causing troubles and use the non-scripted version posted above.
+12 new in 30 days!
