Login - Create Account
Bookmark and Share
Dilla's Scripting Blunders
Filters: 59
Alrighty, I've been dipping a toe into the unknown waters of scripting lately. For some foolish reason I decided to begin work on a Logarithmic Spiral generator component. Spirals are so incredibly awesome, so I thought why not?
smile:| smile;) smile:D
So far the basics look promising, but I'm only getting one revolution (or segment) of the spiral plotted, i.e. it does not spiral towards infinity or zero. I'm guessing there must be some mathematical reason for it, but currently I don't see it. smile:blush:
In case anyone less mathematically challenged than the current me feels like taking a look, here is the filter:
Logarithmic Spiral attempt.ffxml
Filters: 70
From wikipedia:
Many programming languages also provide the two-argument atan2 function, which computes the arctangent of y / x given y and x, but with a range of (−π, π].
You'll have to do a loop if you want a larger range, I think.
"Time flies like an arrow; Fruit flies like a banana." -Groucho Marx
Filters: 59
Indeed. Thank you! smile:)
If desired an angle in the range [0, 2π) may be obtained by adding 2π to the value if it is negative.
Filters: 38
radialCoordinate = math.log(math.sqrt ( x^2 + y^2 ) * 30)
angularCoordinate = 0.5 + math.atan2 (x,y) / (2 * math.pi)
spiralGrd = angularCoordinate + radialCoordinate
spiralGrd = spiralGrd - math.floor(spiralGrd)
route spiralGrd to the output and take a look smile:-)
Njyldgarkn sample cache!
Filters: 59
Nice gradient! And more efficient, apparently. smile:)
But how does one implement proper aa_zones for this? And how does one offset the damned thing to the image center via script?
Filters: 38
Well, I supplied the the code as a starting point. As such it does not make sense to have aa-zones for a gradient (there are no zones...). If you use the gradient to create that threshold like output, it makes sense to use the conditional ("if..then..else") to determine the aa_zone.
you can try using this as aa_zone though: math.floor(spiralGrd * 3), where 3 is the multiplication constant from the radialCoordinate calculation / 10. This should reduce moire aliasing in the center region, while skipping aa calc in the soft large gradients
For the centering you need to think "reverse", i.e. subtract 0.5 from x and y initially so you have 0,0 in the visual center region.
Filters: 59
Sphinx, thanks for your help. I'll get back to experimenting now...
James
James
Is that a spiral formula Sphinx? If i try to center the XY positions by subtracting a 0.5 value i get more of a radial remapped result from the input.
function prepare()
end;
function get_sample(x, y)
radialCoordinate = math.log(math.sqrt ((x-0.5)^2 + (y-0.5)^2 ) * 30)
r,g,b,a = get_sample_map(spiralGrd, spiralGrd, SOURCE)
return r, g, b, a
end;
Filters: 38
James, don't use it for further lookup - just return the value, i.e.: return spiralGrd, spiralGrd, spiralGrd, 1
Dilla - try out radialCoordinate = math.log(math.sqrt ( x^2 + y^2 )) * 30 too, i.e. move the mul. constant outside. It is easier to control the "windings" this way.
James
James
Thanks, it seems no different doing that though. Testing with just a basic gradient to make things more visible i can see rings rather than a spiral -
function prepare()
end;
end;
Or is that how it's suppose to be?
Filters: 59
James, you have to use the same offset on the angular coordinate as well, i.e.:
angularCoordinate = 0.5 + math.atan2 (x-0.5,y-0.5) / (2 * math.pi)
Filters: 38
Oh I get it now James smile:-D well I meant:
add this as the first thing in the script, then you don't have to think more about it.
x,y = x - 0.5, y - 0.5
James
James
Thanks, that makes it work great smile:D
Filters: 59
This is so much fun! I couldn't resist turning this into a full-featured Spiral Gradient component. Submission to the library pending...
Take a look... constructive criticism on code optimization (and the AA_zones hack) is very welcome, cause - you know - it'll learn me. smile;) smile:D
Also, I'm thinking about adding a 'Fixed Size' option.
Spiral Gradient.ffxml
Filters: 38
Cool! Looks quite good - also codewise smile:)
About the aa hack: I think it would be better to do something like math.floor(spiralGrd * 3), since you can't for sure know that the given profile curve works well with your two constants (0.95 and 0.05).
I'd strip away the current aa stuff and simply return the above result.
Oh and another thing - you might want to check if blend_normal is faster than your current solution (honestly I don't know, since you're not doing alpha blending, but lerping instead which is much simpler)
Filters: 38
Oh, I just realized that there is an even better aa_zone to return.
Find the line:
and replace that with
aa_zone = math.floor(spiralGrd)
spiralGrd = spiralGrd - aa_zone
and ensure that aa_zone is not modified afterwards by old script etc..
Filters: 59
Oh yeah! That works like a charm! smile:)
James
James
One useful thing might be to maybe add the new Bezier curve control so the user could shape the profile with a custom curve.
Code wise everything seems quite good also. smile:)
Filters: 59
Yup, sounds good. I'll schedule that into a future update.
Message log wrote:
Script error (line 35): Invalid floating-point value passed to get_sample_curve
With Size, pixels at 1 the script throws an error. Hmmm!?.... smile:|
inujima
Function math.log(x) returns nil value at x<=0.
By such a reason, the value of spiralGrd has been nil value at center coordinate. smile:)
James
James
Just wondering how can you fix this error mentioned, maybe with some sort of value limiting? or would it need to be fixed by the FF developers?
Not that i often use a size of 1 pixel but it would be useful to have a fix/workaround if anyone knows one. smile:)
inujima
It is necessary to rewrite so that zero must not be parameter of math.log().
For example
Code
   -- calculate spiral gradient map
   radialCoordinate = math.log (math.sqrt ( spiralX*spiralX + spiralY*spiralY )) * windings
rewrite like this
Code
   local radial = math.sqrt ( spiralX*spiralX + spiralY*spiralY )
   radial = math.max(radial, 0.00001)
   radialCoordinate = math.log (radial) * windings
Filters: 59
Dilla's Scripting Blunders -- Episode 2
The scripting n00b madness continues... smile;) smile:D
Ok, I've got three points and their circumcircle drawn, but how do I draw the triangle between these points?
CircumCircle.ffxml
Filters: 59
Oh my, there sure are some interesting polygon hit-test algorithms out there -- exciting stuff to dig into... smile:eek: smile;)
http://paulbourke.net/geometry/insidepoly/
Looks like my next scripting assignment is porting one of these to Lua. Personally, I'd choose the first one... smile8)
Filters: 91
Hi Dilla
I just upload a filter tonight based on your Logarythmic spiral. This base has just a script map + an offset component. And it is great. Let me tell you that we could make wonders with it. I'm asking you if you would add some input in your script. I would appreciate much to work again with this logarythmic spiral with more possibilities. Thanks in advance.
I'm creating a second filter with yours. I have discovered a lot of spirograph forms just by playing with logarythmic spiral. I imagine that the possibilities would be multiplied at the infinity with few inputs added to your script. smile:)
Filters: 59
Ghislaine,
unfortunately I'm currently swamped in a project -- which means no time for filter authoring fun. However, feel free to post your suggestions here, and I might look into it once things have calmed down at work.
15,377 Registered Users
+6 new last day!
+90 new in 7 days!
10,102 Topics
+16 new in 7 days!
Recent Wiki Edits:
Follow filterforge on Twitter
