James
James
Filters: 46
When you drag a node from the Components dialog you can hover over a input and it will show a green arrow which will automatically connect it with a wire.
That is a useful feature however i noticed today that this is not available as a feature with a few of the new controls -
Curve Script
Map Script
Curve Control
This is not exactly a bug but more like a missing feature with these controls so i figured i should report it.
I confirm the issue with Curve Script and Map script but not with Curve Control. Could you please test it once again with Curve Control, and if it can be reproduced, let me know your OS version.
James
James
Filters: 46
Hi, i just tested again and it definitely seems like Curve Control works.
I am not sure why but when i tested last time it seemed the same as the other 2 but i guess i was mistaken as it seems to work ok when i test now.
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
