Rod_D
have you seen my eraser?
Filters: 3
Is it possible through scripting or otherwise to offer a drop down menu with all the layer blending modes as a control?
Rod
James
James
Filters: 46
Unfortunately no as a dropdown list is not available as a control. So currently it is best to just have a regular Blend node and int slider.
With scripting you can code your own blend modes, i think it was going to be added as a standard function also which would make things much simpler. Again you would need a slider control however.
I also think FF definitely needs a dropdown list control.
Rod_D
Filters: 3
Thanks for your quick reply.
I agree.A drop down control would be an excellent addition to FF.
Guess i will try and get it to work with check boxes.
Thanks again! smile:)
Rod
You can always just set up multiple blends with preselected blend modes and then hook them up with the switch to use only a selection of blend modes.
But I agree it would indeed be better with a list drop down with configurable labels and integers (indices).
Rod_D
Filters: 3
Sphinx that is a great idea! Thanks.
Rod
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
