| gws2241 | ||||||
| Posted: October 13, 2011 1:02 pm | ||||||
| gws2241 |
This filter doesn't seem to work: it crashes when you try to open a new image. I submitted a bug report.
| Posted: October 13, 2011 1:03 pm | ||||||
Try loading the images first then open your image..Do you have the latest FF3...I remember that was an issue with the previous beta itself...
Maybe its related to this http://www.filterforge.com/forum/read...ssage96110 btw Hurray...I am honored to be the first 3.0 filter... ![]() Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 13, 2011 1:22 pm | ||||||
| jffe |
Sheesh, now I'ma havta look around for those 3-D glasses you sent me CF
jffe Filter Forger |
| Posted: October 13, 2011 2:09 pm | ||||||
| Posted: October 13, 2011 3:03 pm | ||||||
pixel8ted
I also ended up sending a bug report. I have the latest beta version. Double clicking the first bird preset crashes FF 3. (Crashed with my image and also crashed without loading my own image.) BTW, my image never showed the effect...just the preset thumbnail at my image's size with black filling in the difference as it was a wallpaper sized image I experimented on.
| Posted: October 13, 2011 3:05 pm | ||||||
Until FF figures out what is happening there I won't submit an upd ate since everything is up to date.....But heres how to set up images for use with this filter....You need two images........
Use the open image then select one of the images for processing..(mostly to make sure you have the size of canvas correct..) Then go to the controls and load each image into a channel..One for left eye and the other for the right eye....Heres the directions for one of my previous filters.... Se tting up the images to use with this filter: I snapped two pictures of the plant..One photo is used for the green/blue channels and the other photo I moved the camera slightly horizontal to get a different angle. This one is used for the "red" channel. This is one of the examples that I use... ![]() Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 13, 2011 3:13 pm | ||||||
Well I was able to crash FF with this filter...Is this what happened... http://www.filterforge.com/forum/read...ssage96123 If so then nope its FF not the filter.. btw here is another image that I took today for a test....Took 2 images at different angles to get one for the left eye and one for the right eye.... ![]() Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 13, 2011 5:26 pm | ||||||
pixel8ted
If I load an image before selecting your filter, it works.
If I load animage after I select your filter I crash with an internal error message that reads "<class XFW::Logic Error> Last filter action id (0) doesn't match current filter id (9979). FWIW, I can switch images without crashing. It's only if I have no image loaded before selecting your filter that results in a crash. The good news is if I load one of my images using file<open before I select your filter I can play with it. BTW, really cool effect. Creepy Halloween theme using your filter. |
| Posted: October 13, 2011 10:37 pm | ||||||
Posts: 3502 |
This is a known issue, the fix is in the works and will be available in the next program update. |
| Posted: October 14, 2011 3:23 am | ||||||
Posts: 3502 |
Also, this filter seems to fail in the plugin mode. Please use it in the standalone mode until we fix the issue.
| Posted: October 14, 2011 3:44 am | ||||||
my house is all tore up, chuck, or i'd take a look at these. maybe in a week. remind me
| Posted: October 14, 2011 3:59 pm | ||||||
You know I will remind you by posting more samples..Maybe some macro this time..
Ouch that is quite a big job..... Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 15, 2011 6:14 am | ||||||
| Posted: October 16, 2011 7:48 am | ||||||
Like the creepy skulls.. Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: October 16, 2011 11:55 am | ||||||
| Posted: October 16, 2011 5:00 pm | ||||||
wow! and you're right; that last one is really poppin! i like the other bush one and the circuit board one, too. really nice depth separation!
| Posted: October 27, 2011 10:41 pm | ||||||
33,814 Registered Users
+13 new in 30 days!
+27 new in 30 days!
