Zoltan Erdokovy
| Posted: August 30, 2011 5:15 am | ||
Zoltan Erdokovy
I'm about to write a tutorial for this filter
but until then here are a few random examples: Original:
Seam:
Tiling:
Seam:
Tiling:
Seam:
Tiling:
It's no substitution for manual retouching but can give you a head start. |
| Posted: August 30, 2011 5:27 am | ||
Wow Zoltan, this is seriously clever!
And useful! |
| Posted: August 31, 2011 12:53 am | ||
Nice work Zoltan...
| Posted: August 31, 2011 9:20 am | ||
Zoltan Erdokovy
Thanks guys!
| Posted: August 31, 2011 9:30 am | ||
lipebianc
Very useful, Zoltan!
I'm a huge fan of your filters! Congratulations! "From the moment we are born, we start being filtered..." |
| Posted: August 31, 2011 9:51 pm | ||
Totte
This one works extremely well for certain kind of tilings where other approaches works less good. Very nice filter.
- I never expected the Spanish inquisition |
| Posted: September 1, 2011 5:44 am | ||
ok, i dont get it. you seem to be doing the seamless on internal edges (which is usually called 'stitching', not 'seamless'). where are the four images coming from that need this stitching? are you putting those together in photoshop? or am i missing something here (which is probably the case. lol)? or does the filter make four copies of an imported image and then somehow make them seamless? cause if it's the latter, i'm not having any luck/skill in getting this to work.
| Posted: September 1, 2011 10:14 am | ||
Zoltan Erdokovy
The original image is offset so the edges go to
the center where they're more apparent. Take the first image: that is a photo I took. The filter offsets it (also does fade correction) so the seams are obvious, that's the second picture. The next step is laying over the original image to cover up the seams, using a mask created one way or another. (Third pic.) Is that what you wanted to know? I hope I can whip up the tutorial next week because yeah, the controls are kinda many and not very straightforward... EDIT: Clarification. |
| Posted: September 1, 2011 10:30 am | ||
hi zoltan,
i think i understand your explanation, but in practice when i use a square image, the offsets get pushed to the four corners, so there's actually 5 images, not 4 like you're showing above. try it on the life preserver. i think it shows that way there, too. If wishes were horses... there'd be a whole lot of horse crap to clean up!
| Posted: September 2, 2011 2:02 pm | ||
Zoltan Erdokovy
Hmmm I'm not sure what's going on...
Seam preview (Display = 5):
Seamless render (Display = 1):
Tiling preview (Display = 4):
Any of these look similar what you have? Oh btw I'm still on FF2, haven't yet had the time to install v3. |
| Posted: September 2, 2011 2:24 pm | ||
the second one is very similar to what i was getting, four images in the corners and one strong one in the center.
| Posted: September 3, 2011 7:15 am | ||
Zoltan Erdokovy
Alright then, that's how it's supposed to work.
All the "Tiling" images above are like that only it's harder to distinguish the two layers. (Which is kind of the point. Could you post the image you tried? |
| Posted: September 3, 2011 9:10 am | ||
| Posted: September 3, 2011 1:39 pm | ||
Zoltan Erdokovy
Well, that's not an ideal test image because it's already
seamlessly tiling and a big part of the picture has no features at all. Try the filter on images which you actually want to use as tiling textures. |
| Posted: September 4, 2011 2:46 am | ||
rokily dokily
| Posted: September 4, 2011 8:32 am | ||
Zoltan Erdokovy
Here is the reference article for the filter controls:
The seamless tiling filter Please post your further questions and suggestions. |
| Posted: September 7, 2011 3:03 am | ||
| Lucie |
This filter is going to be so useful! Thank you so much!!
Lucie |
| Posted: September 8, 2011 8:53 am | ||
I was searching for this filter and finally found it, but have seen that all the image that Zoltan Erdokovy have put are now missing and not available, so I will try to see how this filter works and how to use it
| Posted: January 18, 2014 6:53 am | ||
Zoltan Erdokovy
I think the images in the second post were the same as I used in
the related article. |
| Posted: January 18, 2014 6:59 am | ||
EAdams
Posts: 447 |
I just discovered this filter, and the results for the photos posted in your article are stunning! I am trying to figure out how to make a seamless repeating pattern out of a simple black form, but I haven't been able to get it quite right. Parts of the original shape in the middle fade out, as do different parts in the corner pieces.
Is it possible at all to get the result (sharp and accurate repetitions of one shape in the middle) I am looking for with this filter? |
| Posted: January 18, 2014 9:40 am | ||
You can try this one as well...
http://www.filterforge.com/filters/5161.html Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: January 18, 2014 9:57 am | ||
EAdams
Posts: 447 |
Thank you, CFandM! That filter gives me exactly what I was looking for (default preset with blur reduced to 0)
| Posted: January 18, 2014 10:36 am | ||
You are welcome Eve...Like this type of filter there are several that do the same thing but they all have a different approach...If one does not work the way you need try a different one..
Sorry for busting in on the thread Zoltan.. Stupid things happen to computers for stupid reasons at stupid times! |
| Posted: January 18, 2014 10:54 am | ||
Zoltan Erdokovy
No worries CFandM, your filter is very much related.
| Posted: January 18, 2014 12:53 pm | ||
| Posted: January 18, 2014 2:17 pm | ||
27 unregistered users.
