Cybersparkle
Posts: 48 |
| Posted: July 11, 2011 9:55 am | ||||||
Cybersparkle
Posts: 48 |
Wow, wow, wow! This is one of the best Van Gogh filters! Thank you so much
| Posted: July 11, 2011 9:56 am | ||||||
lipebianc
JAWDROPPING STUFF!!!
Amazing one, Darrel! Congratulations! "From the moment we are born, we start being filtered..." |
| Posted: July 11, 2011 10:05 am | ||||||
| voldemort |
This is really a fantastic filter
lets all whine for a wine port |
| Posted: July 11, 2011 10:20 am | ||||||
Cybersparkle
Posts: 48 |
Couldnt resist the sunflower!
I used van gogh then americana. |
| Posted: July 11, 2011 10:59 am | ||||||
winning!
| Posted: July 11, 2011 11:44 am | ||||||
| Darrell Plank |
Thanks for the nice comments! I hope that the script node in there will prove useful to other people and that some imaginative people will put it to good use.
Darrell |
| Posted: July 11, 2011 11:56 am | ||||||
lipebianc comment is perfect, IS REALLY VERY JAWDROPPING STUFF!!!
WOW !!! Awesome and excellently done with so much detail and love how it convert the colors into lots of different color shades and the flow is perfectly done is like liquid and gives a perfect effect. And you have only done 2 filters ???? You are already an expert for making this kind of useful and beautiful filter and deserves to be in the best FF filters list, hall of fame of the filters. A millon thanks for making this lovely effect. Please, see this in FF 3.0 and choose the newer other image presets included and see how lovely they look !!! ONE POSSIBLE SUGGESTION When in the settings when the stroke size is at 100 is the biggest it can get, and probably you could get another version of the same filter where where now is 100, the size should be equal to 0 or 10 and then from there to 100, it could growing and getting more thicker and larger the little bits of strokes and so I think it will also give a great effect too and perhaps with the same technique used here have not only one excellent filter, but TWO ! |
| Posted: July 11, 2011 4:23 pm | ||||||
You're right, this does very much resemble the brush-strokes of several of Van Gogh's paintings. Let me see what I can do with this filter.
| Posted: July 11, 2011 6:46 pm | ||||||
| Darrell Plank |
SpaceRay - are you just asking for larger strokes? I think that's what you're saying and I think I'm constrained by the size that Bomber will let me make their inputs. Lowering the "Repeat" value makes for bigger strokes but more spread out. Sadly, bomber kind of insists that strokes in standard position not overlap which means that they can't get larger than the repeat factor allows them. They'll allow them to overlap when they've got H and V chaos so why they're such sticklers when the chaos is zero I don't really understand. Maybe I'm misinterpreting what you're asking for, though. In 3.0 I think you can remap to get larger strokes (you can remap the radius of the ellipse to be larger than 1.0) but I think it then ends up cutting off some of the strokes in bomber. I may experiment around a bit in 3.0 and see if I can't get something acceptable without cutting off "mid-stroke", so to speak.
BTW, I did a surface version of this filter where the strokes come out 3D for a kind of "impasto" version. I wish there was a way through parameters to turn on and off whether the output is a "surface" or not. As it is, if I want to submit this, it will have to be an entirely separate filter which I'm kinda embarrassed to do, but I may anyway. Darrell |
| Posted: July 11, 2011 9:02 pm | ||||||
Kochubey
Amazing!!!
| Posted: July 12, 2011 3:25 am | ||||||
I made a little mod of this by combining it with my Brush Strokes filter. It looks more like a traditional painting, but it's less stylistic.
| Posted: July 12, 2011 12:22 pm | ||||||
Carlos Carreno
Wow, Amazing.
| Posted: July 12, 2011 9:20 pm | ||||||
Professor Fate
I love it! Can hardly wait to use it. Thanks!!!
| Posted: July 13, 2011 4:39 pm | ||||||
| Darrell Plank |
As confirmed by FF people, the Lua library on the Mac is buggy and calling atan2() caused it to crash which is what Mac users were seeing. I submitted a new version that has a home rolled version of atan2 which does no library calls. Hopefully, this will fix the problems you Mac users were seeing.
Darrell |
| Posted: July 13, 2011 8:40 pm | ||||||
| Darrell Plank |
Well, even after I put in code so that the Lua only does arithmetic, the Mac people say it's still crashing on them. At this point there's not much I can do. If scripting can't even do basic arithmetic, then there's not much hope of doing scripting on the Macs at all. I apologize to all the Mac people. This may be doable using derivative components and maybe I'll give that a shot sometime but meanwhile the Mac people apparently need to steer clear. I really hope that the FF people look into whatever is causing Lua to fail so miserably on Macs. If they can give me a workaround, that would be great.
Sigh. Darrell |
| Posted: July 14, 2011 11:19 am | ||||||
Dave S
Very slick filter! Love the results it produces.
That's a way of using the bomber transform that i never would have thought of! |
| Posted: August 22, 2012 12:34 pm | ||||||
| Posted: August 23, 2012 2:25 am | ||||||
| Posted: August 23, 2012 2:28 am | ||||||
| Posted: August 23, 2012 2:31 am | ||||||
| Posted: August 23, 2012 2:42 am | ||||||
| Posted: August 23, 2012 2:44 am | ||||||
| Posted: August 23, 2012 2:46 am | ||||||
| Posted: August 23, 2012 2:49 am | ||||||
| Posted: August 23, 2012 4:49 am | ||||||
| Posted: August 23, 2012 4:52 am | ||||||
Casper
Posts: 2 |
For some reason, FF crashes every single time I try to download this filter, and keeps crashing on restart until I manually delete the filter from the drive. Running newest version of FF. Anyone else having problems?
"<XFW::Exception> Application encountered an unrecoverable critical error and will be terminated." |
| Posted: August 23, 2012 10:21 am | ||||||
Can you download other filters? Does it only happen with this one? There is no real reason why it would not be able to download one filter, unless there some problem in the LibraryStructure.xml and it is damaged. Please, you can try also some of possible fixes available in my thread. BEFORE Posting an error downloading FF filters PLEASE see this thread |
| Posted: August 23, 2012 4:24 pm | ||||||
| Darrell Plank |
Casper -
I assume you've got a Mac. As I mentioned in one of the earlier posts, there is a LUA bug on the Mac that keeps this from running. Filter Forge knows about the bug and knows it's their bug to fix but doesn't seem in any hurry to do so. I rewrote the filter to avoid using a trig function from LUA which I assumed might be the problem but even with the purely arithmetic version it still fails. I wish I could help you but there's not much I can do until Filter Forge gets this corrected. SpaceRay - Glad you like it and thanks for the great examples! Darrell Darrell |
| Posted: August 23, 2012 7:44 pm | ||||||
| Posted: August 23, 2012 7:55 pm | ||||||
| Posted: August 23, 2012 7:56 pm | ||||||
Casper
Posts: 2 |
@Darrell - yup, on a Mac =) I'll just wait for FF to come up with a patch or something. Thanks for your help, and keep up the good work! =D
@SpaceRay - yeah, only problems with this one filter, thought it was best to ask at the source, but I'll take your advice to heart =) |
| Posted: August 24, 2012 3:11 am | ||||||
Inujima did a small replacement using emme's little "rotation" trick a while ago on a separate forum. The version does not use LUA and the results are pretty much the same. So if FF is going crashy-doodda on you just use that.
http://www.filterforge.com/upload/for...ript.ffxml |
| Posted: August 24, 2012 3:38 am | ||||||
| Darrell Plank |
I'll give it a shot skybase. Thanks. Is that using the derivative operator? I was thinking that ought to work but hadn't looked into it seriously.
Darrell |
| Posted: August 24, 2012 4:00 am | ||||||
| Darrell Plank |
Hey Skybase -
Yeah, it uses derivative. A little chagrined with myself for not doing this but great job to Inujima! Darrell |
| Posted: August 24, 2012 4:08 am | ||||||
I'm sorry that was an error: the work does NOT use emme's stuff, this is all Inujima rework alone. Emme happened to produce a similar method only it dealt with two gradients, a derivative and a lookup component. Thought that was pretty cleaver too. Either way, yes it uses the derivative operator. |
| Posted: August 24, 2012 4:12 am | ||||||
I have used the NEW updated without script version of this awesome filter to make some possible variations of this filter
Nice Van Gogh Flow filter variations of the main shape used I hope that you do not mind that I have modified the filter and changed the shapes, and is still belong all to you and your good way of building and making this great filter |
| Posted: September 9, 2012 5:33 am | ||||||
| Darrell Plank |
Not at all, SpaceRay - nice stuff. I've got some variations in mind myself as soon as I get a teeny bit of time. Thanks for the acknowledgement!
Darrell |
| Posted: September 9, 2012 10:56 am | ||||||
Thanks Darrell for answering and for the comment
Good to know that you may make some variations based on this that could be interesting and good to see and use. I hope that you can make it and will wait for it.
Of course that you deserve it and thanks to YOU for making this filter. |
| Posted: September 9, 2012 4:44 pm | ||||||
| Darrell Plank |
Okay, I finally incorporated inujima's changes so this should work for Mac users now. Thanks inujima! I sent mail to ask permission for this but never heard back so hopefully he (she?) is okay with this. I think inujima's name is on there as author also. I wanted to update the original filter rather than open up a brand new one so that people who are pointed to that one get the update. Bonus - it's much faster as well which isn't surprising since we're now using Filter Forge's native routines rather than LUA script. Also, I'm going to put in an "Impasto" version here in a bit which will make the strokes "three dimensional". It's not a replacement - just a (slower) variation on this filter.
Darrell |
| Posted: October 14, 2012 11:18 am | ||||||
I think that maybe this same excelent and well done way of doing things in this filter could be made another filter that could use different shapes instead of enlongated lines as it uses this filter.
I mean that this is too good to be made just one filter that uses one shape, and would be good to have more alternative that could produce different results Just a suggestion |
| Posted: August 5, 2013 11:20 am | ||||||
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
