Login - Create Account
Bookmark and Share
Default Filter Settings
KendraSchmidt
If I use a filter and alter its settings and don't like the results of the alteration, is there a simple way to restore the default settings of that filter?
Orteil
but certainly
Filters: 49
All filters have several presets; when you alter a filter's settings, you're not actually changing the preset until you click "Upd ate preset" in the presets screen. Clicking on a preset will reset the settings to that preset. You can also save your current se ttings to a preset if you want.
Hope this helps !
KendraSchmidt
Thank you. Does this mean that if I click on a Default Factory Preset for a filter, tweak the Preset's settings, then click on another Factory Preset, THEN go back to the Default Factory Preset - does this mean that it will now show the image with the actual default settings for the Default Factory Preset? Or will it show the image with the altered settings that I previously plugged in while clicking around the Factory Presets?
I hope that's not too confusing.
Filters: 204
Yep....If you choose the first preset and move the sliders around then go to another preset....The first one when click on will have not remembered your settings.....You can however click the arrow for the sub-menu and choose to add preset...This will add a preset at the end of the line in the presets so in case you liked the way you tweaked it...
KendraSchmidt
This sounds perfect, thank you! I was hoping it wouldn't keep my alterations, unless I explicitly asked for it. This helps, thank you.
Filters: 204
You are welcome Kendra smile:)
uglyboys
Uglyboys
Filters: 75
http://www.filterforge.com/features/
see details about presets here
saurabh.gayali@gmail.com
infiniview
digital artist
Factory smile:)
15,411 Registered Users
+10 new last day!
+17 new last day!
10,110 Topics
23 unregistered users.
Recent Wiki Edits:
Follow filterforge on Twitter
