Hey people, it's been a while.
I made a cool bookmarklet that let's you watch a filter in 3D on it's own page. It uses WebGL so you need a browser like Chrome.
Just go to http://ffpreview.sjeiti.com/, drag the link to your bookmarks bar, go to a filter page and press the bookmark.
It's a start, I'll be expanding it with more features. Just watch this thread.
Hmm.. is some special version of Chrome required? According to the About Menu, my Chrome version is the latest (11.0.696.71), but when I try WebGL demos I get a message that tells me to upgrade Chrome..
I don't think so, I have v11.0.696.71 as well. Can you run any of the WebGL examples at Three.js? (which is what I used to create the preview) It could also be that your graphics card doesn't support WebGL.
Oh... hold on... I totally forgot (did that months ago): you have to initialize Chrome with extra parameters to enable WebGL, so call: chrome.exe --use-gl=desktop.
...and it will look like this:
Works for me smile:D this is pretty neat!
You just changed the way I look for filters forever. smile:)
softhunterdevil
check my filters
Filters: 11
What about a cube ? And how does it take metal / reflection map ?
check my filters please
lipebianc
FFF = Filter Forge Fan
Woah! Just found it! smile:)
Congratulations!!
Soday maybe FF team could implement this funcion directly on the website smile;)
softhunterdevil
check my filters
Filters: 11
cant preview this filter http://filterforge.com/filters/9572.html whats the problem ?
lipebianc
Same here for the mentioned filter.
I'm using Firefox 4, btw.
Yeah cube and other primitives are in the pipeline. The problem is that the open source lib I made it in (three.js) is quite new. The only primitives working in WebGL are a sphere and a torus. And I first want to fix the tiling, which is now only possible if you alter the uv-coordinates of the object (which is not really what you want).
Haven't really checked all the reflection and metal mapping and stuff. Don't know much about that part of 3D either so it'll take some time before that's properly implemented.
Regex looking for filter number fails somewhere...
Mike Blackney
Filters: 57
This is really nice!
I've updated it a bit... you can now choose between torus, sphere, and plane (still having issues with the cube in WebGL). Filters without maps are now rendered with a simple phong shader. Browsers without WebGL now do software rendering but with a message how to get WebGL running.
I was also thinking for the plane... or maybe a separate option :: just leave the plane flat (as the image) and just move the lights about.
- another update -
fixed the above flat plane (move light with mouse, height of light with wheel)
fixed the filternumber bug
added cookie: it remembers the last 3D object
That's it for now, I really should be doing other stuff... smile:-p
...and just a small screenshot of the new flat view:
Fantastic idea.
I was like, how on Earth could this thing work so fast and smooth in my browser, but then I remembered that I have Firefox 4, which probably has WebGL built-in. Works perfectly by the way.
(We tried to implement a similar feature, but we didn't use WebGL. We used plain canvas with Javascript rendering, but the result wasn't anywhere near as fast as your version.)
sjeiti,
i can use firefox and i've got the ffpreview thing set up, but i get a message when i click on a filter and hit the ffpreview of: Firefox 4 (iOS: about:config => webgl.mochitest_native_gl=true) . what the heck is that? what is "iOS" and where do i find it and the same with "about:config =>"??
and is there a firefox 4? when i hit the update firefox, it gives me a message to update to 3.5.4 version. so, i'm a bit confused here.
hate to be a pain, but you cant drag the "ffpreview" thing to the favorites bar in i.e. and there is no message 'how to get webgl running' for i.e. I'm using i.e. 8.xx
There's a Firefox 5.0 beta already smile:)
Btw, I'd recommend you backup your current Firefox installation before upgrading to Firefox 4 or 5beta: Mozilla have introduced a pack of doubtful features and removed some of the needed ones.
thanks, gmm smile:)
Well, if you type 'about:config' in your Firefox adress bar you get a whole lotta options you can set. Just look for the stuff starting with 'webgl'. Btw, I didn't actually see an option called 'webgl.mochitest_native_gl' but I figured it was an iOS thingy (I'm on pc and too lazy to check it on the Mac I have smile:-p)
This was build with Three.js, they did all the hard work (although I did see some of my code back in the sphere primitive which was ported from Papervision3D).
I could send you the code if you want. Or you could wait a while. For one the Three.js library is not finished (for instance: WebGL texture repetition was only implemented yesterday, but doesn't work for the normal shader yet (it does for the phong shader that is used for the simple textures)). And I want to extend it a bit with lighting- and texture controls.
Targos
Game Dev
This thing is amazing!
Awesome stuff Sjeiti......
Craig if you use Firefox4 you can type the "about:config" in the web addy bar...Then you will be asked about some warranty blah blah..Just click OK or Next to get to the window with a lot of text........At the very bottom of that screen you will find the adjustments to make.....I got the same thing you did but here are my new settings for this to work....
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
