Mongoose King
Ok, I have made a rather lovely filter that does stitching on a bit of fabric, however there's something that annoying me about it.
It only takes about 1 minute to render a 512x512 on my laptop with no AA, however, 30 seconds of that is it doing nothing at all before the first little square in rendered. Which is really annoying, if I tweak the colour I have to wait 30s before I can see a single square of the new colour. Once it starts going, the rest of the squares render pretty fast. I've never seen a filter have such a long delay before the first square is drawn on an otherwise quick filter, can anyone help me figure out the reason for this big delay? Stitched Canvas4.ffxml Release the Mongoose! |
| Posted: October 20, 2010 5:36 am | ||
Hey Mongoose. I agree, nice filter!
Instead, I managed to re-arrange the order of components and add thresholds to speed up the filter without modifying the end-result. The first box now appears 3x sooner, and I'm guessing the rest of the rendering is a little faster as well. Not perfect, but a start. Also, that fade fabric with its two blurs frightens me. You might want to think of something quicker for that. Stitched Canvas4 Edit.ffxml |
| Posted: October 20, 2010 3:46 pm | ||
Mongoose King
Thanks, that's really great, it's much faster, and the new position for the noise distort is far more sensible, it makes the threads way more unique than how it was before. It only takes 55 seconds for me, with AA on, which I think is about right for a filter of this kind of detail.
Yea, the fade fabric option was an afterthought I added after playing about with some denim fabrics, I didn't like having those blurs there, I've mostly kept it switched off, I can't get it to give the kind of jeans pocket type fade I want anyway. With my own playing, I found that taking off the blur for the height map took about 10 seconds off (about 5 when I did it on your version), however the surface was intolerably rough after that, I may replace the whole of the fabric part if I can think of a way to make a smooth enough pattern without blur. The other blur that makes a shadow around the thread, I tried thking that out too, also a bit faster, but again, I just don't like it without. I also realised I've made something of boo-boo, I added the colour right at the start for the stitching, then took the bump from that, so, if you use dark thread, it goes wrong.. I'll have to make it white then use a threshold or something to add the colour at the end. Thanks for the help. I've not really considered the order of components that much, I've only been thinking about which ones the wiki says are fast or slow. Release the Mongoose! |
| Posted: October 20, 2010 6:15 pm | ||
Mongoose King
Well... I added the changes to my version of the filter.... however I had already added a few extra options and realism enhancement and once I worked it all together, it's kind of back where it started... still working on a few things.. I'll post the resultant monstrosity again when I have added all the extra mess I want to. I'm working hard to undo all your good work with a better height map, scaling for the stitching, and fixing the colour mistake, fixing the height where the stitching crosses and a few other tweaks.
| Posted: October 20, 2010 8:15 pm | ||
Mongoose King
| Posted: October 21, 2010 9:27 am | ||
