Cybersparkle
I am have just bought only my second laptop. It is windows 7 professional 64 bit with i5 processor. My old 2006 win xp home media sp3 32 bit is still running fine. I have never attempted to put old software on a new computer and honestly dont know where to begin. My ideal goal is to have my image editing software & heavy duty stuff on the win 7 and have the old xp for internet surfing & lighter things. The i5 processor is the best I could afford & I hope that I will have enough power (4GB Memory / 500GB Hard Drive) to be able to run PSE4, FF & other plugins properly.
I use photoshop elements 4 on the xp 32 bit and use FF mostly as a plugin in the PSE4. According to the system requirements listed on this site, if I were using a 64 bit processor- I can only use FF as a standalone, but not as a plugin. Is this still true?
Does anyone have any suggestions as to the best way to transfer PSE4 fr om win xp 32 bit to win 7 64 bit? Do I just use my old PSE4 installation disc on win 7? What about virtual operating system software like vmware fusion/ virtual box or parallels? Has anyone had experience with the xp compatibility mode on FF in win 7 professional? How can I keep FF as a PSE4 plugin on my new win 7 64 bit system? Or should I just bite the bullet to upgrade to PSE 8 and install it alone on the win 7 and keep PSE4 on the old xp- & would FF still be a standalone with PSE8 on a 64 bit win 7?
I hope I am not rambling and tried to be clear- but this is all new to me and I just dont know wh ere to begin. smile:?:
Any advice at all is appreciated...
Not exactly: you can run a 32-bit host application and use FF as a plugin — regardless of your OS and CPU. You can install both the 32-bit and 64-bit versions of the host application and use FF with the 32-bit one (not sure if PSE4 has a 64-bit version at all).
Cybersparkle
Thank you for replying! I am not sure what "host application" is referring to- the operating system or the software? Are you saying that I can run PSE4 32 bit on a 64 bit win 7 operating system with FF as a plugin? Yayy, if so that is good news smile:)
Would the simplest route be just to try to install the PSE4 disc on win 7 first & see if FF will open as a plugin?
I know PSE4 is sooo old, it probably is not 64 bit- came out in 2004 or 2005.
A host app is the graphic software into which a plugin is plugged smile:) The one which you run Filter Forge from.
Exactly.
I think yes. If PSE4 is that old as you say it will surely be 32-bit.
Cybersparkle
Just an update so far...
I have win professional, it has windows xp mode installed on it and just to be safe, I downloaded the old PSE4 in xp mode and it is working beautifully (thank goodness!) From what I understand windows 7 home does not run xp programs, but win 7 prof does.
I am hoping that when I transfer FF2 over from the old computer in xp mode, then FF2 will not have any problems with the 64bit system because xp mode runs in 32 bit.
33,815 Registered Users
+14 new in 30 days!
+27 new in 30 days!
