Mongoose King
Mongoose King
Filters: 21
Ok, so I've tried the FF2 beta, but I'm sticking with FF1, how do I get the 'Open this filter in Filter Forge' button back to opening in FF1?
My first thought was I should reinstall FF1, but the link's gone from the download page!
Release the Mongoose!
Totte
Übernerd
Filters: 107
Try this link:
The not installed page
Mongoose King
Mongoose King
Filters: 21
Thanks, I dunno if that solution worked, because I already guessed the url for the filter forge 1 setup file to be http://www.filterforge.com/download/Filter Forge Setup.exe and typed it straight in the address bar, and it worked after I reinstalled it.
I've found a new and slightly more worrying problem now though, some old filters have just been updated to 2.0, on the pages for them the button says
"To open this filter, you should have Filter Forge 2.0 or higher installed on your computer. You can open this filter under Filter Forge 1.0 (this will load an older revision of this filter), but the results may differ from the examples shown on this page.".
However, when I open them with 1.20, it gives me the error saying you need a newer version of filter forge to open this filter. If I click on a filter that I have already downloaded, it works fine and just brings up the version I already have, but ones I've not used in 1.20 before, it just tells me it's not up to date. I don't know if this is because I had the beta installed before and it's messed something up, or if it's broken for everyone using 1.20.
saurabhgayali
Saurabh Gayali
Filters: 84
i have faced same problems.
I had FF 1 and FF 2 both on my system
with some of my fav filters in FF 1 and some on FF 2
I used to open FF 2 filters manually in FF 1.
Some worked cause they were not using features exclusive of FF 2 or any scripts having unsupportive in FF 1
HOpe this info helps you
saurabh.gayali@gmail.com
11 unregistered users.
