moonrancher
Filters: 10
I submitted this through the normal system, but want to add simple extra details:
Filter being used was my own, from the submitted library, and using the default
setting for Simple Fine Weave. (And I've used it very often, too.)
Called from Photoshop layer 6 image is 900x1200 px.
After the exception, it finished the render and passed back to PS CS2 with no problems.
-------------the crash report follows-----------------
Operating system: Windows XP (5.1 build 2600) Service Pack 2
Physical memory: 2046 MB
Number of processors: 2
Processor info: Genuine Intel® CPU T2500 @ 2.00GHz, 1999MHz
Filter Forge x86-SSE2 1.002.1516.49458 Release-SSE2, May 24, 2006 14:54 [7/27/2006 10:08:37 PM]
Exception caught at thread 00000350:
<class XFW::Kernel::SystemException> Access violation at address 005DE937 (read at address 00000000).
onyXMaster
Filter Forge, Inc.
Known bug, probably fixed (fix will be available in the next release). The "probably" is there because we can't repeat it in-house (it occurs only on multicore/multiprocessor systems -- although we have some, both Intel and AMD-based, we still can't catch it), so we just improved the handling code, tightened screws here and there and hope it will help. Guess we'll see with the next release.
Thanks for the detailed report though, it's appreciated smile:))
moonrancher
Filters: 10
smile:) I have worries, that I can't keep up with the forums now that they've grown so huge and I'll miss when you send out the update. I hope you'll email us about it, or make it easy to tell when we try to download new filters. Keep up the fine work!
Filter Forge uses has a built-in automatic updater that activates when you click Download More Filters, so you won't miss it smile:) And of course, we'll announce the update here on the forums and send an email to all registered testers.
19 unregistered users.
