tigerAspect
Filters: 9
This ... is really odd. There's certain filters that are just broken, others that are just messed up. Here's the default preset on Vintage Clay Tile (the Diffuse Map):
ummm works fine for me smile:| is there another that we can test smile:)
tigerAspect
Filters: 9
The excellent Cemetery Fence, is flat-out broken. smile:?:
tigerAspect
Filters: 9
Totte's aged wooden floor is wrong, and I actually know why with this one: the remapper from the "Dirt brightness" to the Brightness value of the Brightness/Contrast node is somehow set to Min. 0 / Max. 0.
tigerAspect
Filters: 9
The Super-nifty Wood Fortress is wrong. smile:cry:
Totte
Übernerd
Filters: 107
Tiger I know what happened!
You are using FF2 Beta, there was a strange bug in Beta 3 that was hotfixed a few hours after the release, where settings IN filters were changed when a Filter was opened.
What make me suspect that is that that was one of the issues I had, values "set" in the filter was randomly set to zero.
// Totte
tigerAspect
Filters: 9
Is there a different way to get the hotfix? I re-downloaded FF, re-installed, checked for updates in FF, deleted and re-downloaded your filter, and I'm still having the same issue. Do I need to completely delete FF before reinstalling? My version number is 2.005
Totte
Übernerd
Filters: 107
Strange, they hotfix was just the latest download. Check that you get the latest download and not just get a copy of the previous one from you cache, I don't know the actual build number for the hotfix for Windows (but GMM or Vlad might help you with that)
tigerAspect
Filters: 9
I'm on OS X smile;)
Build: Filter Forge universal 2.005.16491.47410 Release-10.5, April 13, 2010 12:29.
Totte
Übernerd
Filters: 107
Same version as I have, no problems here though. I had to check with my ages wooden floor filter, then remapper is as it should be.
Goto ~/Library/Application Support/FilterForge 2/System/Library and manually remove "Library_7559-3.ffxml" (Which is my aged wooden floor filter), and download it again from the library. If it still fails, check any messages on "System messages.app" from FilterForge.
tigerAspect
Filters: 9
No joy, it's still the same.
For added weirdness, here's the screenshot of it in the built in filter browser:
try doing a refresh of the various web pages. sometimes it's just a cache not being refreshed and not the actual filter.
tigerAspect
Filters: 9
Nope, no change.
BLUEFROG
Filters: 6
I'm not seeing any of these problems with these specific filters on OS X 10.5.8 [FF 2.005.16491.47410 Release-10.5].
how about the size slider? have you got that set down from max? and are these filters surface or simple? and if surface, have you turned on AO or set the height differently?
Totte
Übernerd
Filters: 107
Tiger, looks like you are using the "old way" of library browsing.
Am I correct? Maybe that caches things somewhere else. I've never used that, only the web so I cannot tell. Switching over to test it. No, didn't screw anything up, but I found a few good filters I missed smile;-)
Mail me Tiger when you are online. I just cannot help myself, I love solving mysteries like this, I do that whenever I get a chance, I like sharpening my skills.
tigerAspect
Filters: 9
Size slider is at max, they're a mix of Surface and Simple, using the default presets.
I've deleted and re-downloaded the filters at least 4 times using both the web interface and built-in filter browser.
I'm convinced that this is a bug, because I distinctly remember rendering Cemetery Fence before with no problems.
I'm using 10.6.3, if that makes a difference.
tigerAspect
Filters: 9
One more thought, can someone toss me their working copy of one of the filters affected? I want to see where in the chain it's going wrong.
This is really wierd, FF is randomly, but consistently changing value set inside the filter, for Wood Fortres, there's a bunch of Bias and other Curves that have had their values set so that they are the same as Linear curves.
Totte
Übernerd
Filters: 107
Here, my wood filter...
tigerAspect
Filters: 9
Phew. Ok, THAT works. Freaky. If I download it, it's still wrong.
tigerAspect
Filters: 9
I ran the 2 versions though diff, here's the results: broken Library download is first or "<", working is after or ">".
so the format is:
line number
< first version
> second version
19,20c19,20
< <G source="brightnesscontrast 01" value="1.3999999999999999"/>
< <B source="brightnesscontrast 01" value="2.1000000000000001"/>
> <G source="brightnesscontrast 01" value="1.4"/>
> <B source="brightnesscontrast 01" value="2.1"/>
25c25
< <Maximum value="2.5499999999999998"/>
> <Maximum value="2.55"/>
27c27
< <G source="slidercontrol 04" value="1.3999999999999999">
> <G source="slidercontrol 04" value="1.4">
29c29
31c31
< <B source="slidercontrol 04" value="2.1000000000000001">
> <B source="slidercontrol 04" value="2.1">
33c33
45c45
< <Opacity value="0.23999999999999999"/>
> <Opacity value="0.24"/>
65c65
< <Color source="switch2 01" red="0.69999999999999996" green="0.46600000000000003" blue="0.34999999999999998" alpha="1"/>
> <Color source="switch2 01" red="0.7" green="0.466" blue="0.35" alpha="1"/>
67,68c67,68
< <HRange value="0.050000000000000003"/>
< <LRange value="0.14999999999999999"/>
> <HRange value="0.05"/>
> <LRange value="0.15"/>
70,71c70,71
< <MortarWidth value="0.050000000000000003"/>
< <BevelWidth value="0.20000000000000001"/>
> <MortarWidth value="0.05"/>
> <BevelWidth value="0.2"/>
77c77
< <Chaos value="0.14999999999999999"/>
> <Chaos value="0.15"/>
84,85c84,85
< <Minimum value="0"/>
< <Maximum value="0"/>
> <Minimum value="-1"/>
> <Maximum value="-0.16"/>
93c93
101,102c101,102
< <Background red="0.54651162790697705" green="0.53803857941229505" blue="0.53803857941229505" alpha="0"/>
< <Roughness value="0.20000000000000001"/>
> <Background red="0.546511627906977" green="0.538038579412295" blue="0.538038579412295" alpha="0"/>
> <Roughness value="0.2"/>
111c111
< <Details value="0.40000000000000002"/>
> <Details value="0.4"/>
128c128
< <Color red="0.52325600000000005" green="0.45302100000000001" blue="0.32044299999999998" alpha="1"/>
> <Color red="0.523256" green="0.453021" blue="0.320443" alpha="1"/>
133c133
< <Color red="0.96124031007751898" green="0.95732611100472198" blue="0.76005047773571299" alpha="1"/>
> <Color red="0.961240310077519" green="0.957326111004722" blue="0.760050477735713" alpha="1"/>
137,139c137,139
< <Color2 source="colorcontrol 02" red="1" green="0.98039215686274495" blue="0.83921568627451004" alpha="1"/>
< <Color3 source="colorcontrol 02" red="0.74901960784313704" green="0.34509803921568599" blue="0.266666666666667" alpha="1"/>
< <Position1 value="0.16666666666666699"/>
> <Color2 source="colorcontrol 02" red="1" green="0.980392156862745" blue="0.83921568627451" alpha="1"/>
> <Color3 source="colorcontrol 02" red="0.749019607843137" green="0.345098039215686" blue="0.266666666666667" alpha="1"/>
> <Position1 value="0.166666666666667"/>
141c141
< <Position3 value="0.83333333333333304"/>
> <Position3 value="0.833333333333333"/>
164c164
< <Distortion source="slidercontrol 08" value="0.14999999999999999">
> <Distortion source="slidercontrol 08" value="0.15">
166c166
< <Maximum value="0.30499999999999999"/>
> <Maximum value="0.305"/>
168c168
< <Roughness source="slidercontrol 10" value="0.70999999999999996">
> <Roughness source="slidercontrol 10" value="0.71">
170c170
< <Maximum value="0.69999999999999996"/>
> <Maximum value="0.7"/>
172c172
> <Scale source="slidercontrol 09" value="2.85">
189,190c189,190
< <Scale value="2.1299999999999999"/>
< <Stretch value="0.10000000000000001"/>
> <Scale value="2.13"/>
> <Stretch value="0.1"/>
197,198c197,198
< <Distortion value="0.53000000000000003"/>
< <Roughness value="0.48999999999999999"/>
> <Distortion value="0.53"/>
> <Roughness value="0.49"/>
206c206
< <BaseColor source="colorcontrol 01" red="0" green="0.75019599999999997" blue="0.37490200000000001" alpha="1"/>
> <BaseColor source="colorcontrol 01" red="0" green="0.750196" blue="0.374902" alpha="1"/>
208c208
< <LRange source="slidercontrol 02" value="0.23999999999999999">
> <LRange source="slidercontrol 02" value="0.24">
210c210
< <Maximum value="0.40999999999999998"/>
> <Maximum value="0.41"/>
212,213c212,213
< <SRange value="0.050000000000000003"/>
< <Roughness value="0.70999999999999996"/>
> <SRange value="0.05"/>
> <Roughness value="0.71"/>
224,225c224,225
< <Scale value="0.029999999999999999"/>
> <Scale value="0.03"/>
237,238c237,238
< <Scale source="slidercontrol 03" value="2.5499999999999998">
< <Minimum value="2.3700000000000001"/>
> <Scale source="slidercontrol 03" value="2.55">
> <Minimum value="2.37"/>
247c247
< <Contrast value="0.20000000000000001"/>
> <Contrast value="0.2"/>
254c254
< <Roughness source="slidercontrol 03" value="0.20000000000000001">
> <Roughness source="slidercontrol 03" value="0.2">
269c269
< <Roughness value="0.73999999999999999"/>
> <Roughness value="0.74"/>
291c291
< <NewAlpha source="invert 01" value="1.2749999999999999"/>
> <NewAlpha source="invert 01" value="1.275"/>
297c297
< <Value value="0.68576300000000001"/>
> <Value value="0.685763"/>
302c302
< <Value value="0.68586199999999997"/>
> <Value value="0.685862"/>
307c307
< <Value value="0.53804799999999997"/>
> <Value value="0.538048"/>
317c317
< <Value value="0.40402399999999999"/>
> <Value value="0.404024"/>
322c322
< <Value value="0.69135500000000005"/>
> <Value value="0.691355"/>
327c327
< <Value value="0.59999999999999998"/>
> <Value value="0.6"/>
332c332
< <Value value="0.89000000000000001"/>
> <Value value="0.89"/>
337c337
< <Value value="0.42999999999999999"/>
> <Value value="0.43"/>
342c342
< <Value value="0.070000000000000007"/>
> <Value value="0.07"/>
347c347
< <Value value="0.71999999999999997"/>
> <Value value="0.72"/>
350,352c350,352
< <Source1 source="assemblergb 01" red="1" green="0.066000000000000003" blue="0" alpha="1"/>
< <Source2 source="brightnesscontrast 02" red="1" green="0.77200000000000002" blue="0.113" alpha="1"/>
< <Source3 red="1" green="1" blue="0.16800000000000001" alpha="1"/>
> <Source1 source="assemblergb 01" red="1" green="0.066" blue="0" alpha="1"/>
> <Source2 source="brightnesscontrast 02" red="1" green="0.772" blue="0.113" alpha="1"/>
> <Source3 red="1" green="1" blue="0.168" alpha="1"/>
355,357c355,357
< <Source6 red="0" green="0.76000000000000001" blue="1" alpha="1"/>
< <Source7 red="0" green="0" blue="0.99199999999999999" alpha="1"/>
< <Source8 red="0.996" green="0" blue="0.98799999999999999" alpha="1"/>
> <Source6 red="0" green="0.76" blue="1" alpha="1"/>
> <Source7 red="0" green="0" blue="0.992" alpha="1"/>
> <Source8 red="0.996" green="0" blue="0.988" alpha="1"/>
360c360
< <Source11 red="0.74099999999999999" green="0.74099999999999999" blue="0.74099999999999999" alpha="1"/>
> <Source11 red="0.741" green="0.741" blue="0.741" alpha="1"/>
374c374
< <Low source="slidercontrol 01" red="0.86431400000000003" green="0.76980400000000004" blue="0.67019600000000001" alpha="1">
> <Low source="slidercontrol 01" red="0.864314" green="0.769804" blue="0.670196" alpha="1">
376c376
< <Maximum red="0.80232599999999998" green="0.70996800000000004" blue="0.61262799999999995" alpha="1"/>
> <Maximum red="0.802326" green="0.709968" blue="0.612628" alpha="1"/>
379,380c379,380
< <Minimum red="0.68604699999999996" green="0.34301300000000001" blue="0.0425455" alpha="1"/>
< <Maximum red="0.29069800000000001" green="0.172013" blue="0.0056336800000000003" alpha="1"/>
> <Minimum red="0.686047" green="0.343013" blue="0.0425455" alpha="1"/>
> <Maximum red="0.290698" green="0.172013" blue="0.00563368" alpha="1"/>
389c389
< <Smooth value="0.41999999999999998"/>
> <Smooth value="0.42"/>
395c395
< <Threshold value="0.10000000000000001"/>
> <Threshold value="0.1"/>
401c401
< <Shape value="0.26000000000000001"/>
> <Shape value="0.26"/>
403c403
< <FVariance value="0.14000000000000001"/>
> <FVariance value="0.14"/>
405,406c405,406
< <Minimum value="0.029999999999999999"/>
< <Maximum value="0.90000000000000002"/>
> <Minimum value="0.03"/>
> <Maximum value="0.9"/>
408c408
< <Frequency value="0.040000000000000001"/>
> <Frequency value="0.04"/>
414,419d413
< <SettingsOverride>
< <Size value="0"/>
< <Variation value="0"/>
< <Seamless value="0"/>
< <ResultBlending value="0"/>
431,457d424
< <Ambience>
< <AmbientLight red="0" green="0" blue="0"/>
< <Shadowing value="0"/>
< <CurrentOcclusionSettings>
< <RayDirections value="4"/>
< <TraceDistance value="0.20000000000000001"/>
< <RayJittering value="true"/>
< <RayBounce value="true"/>
< <AvoidStreaks value="true"/>
< <DirectSamples value="0"/>
< <ROQuality value="3"/>
< </CurrentOcclusionSettings>
< <CustomOcclusionSettings>
< <RayDirections value="16"/>
< <TraceDistance value="0.29999999999999999"/>
< <DirectSamples value="1"/>
< <ROQuality value="10"/>
< </CustomOcclusionSettings>
< <ArtisticSettings>
< <BlackPoint value="0"/>
< <Midtones value="0.5"/>
< <WhitePoint value="1"/>
< </ArtisticSettings>
< </Ambience>
464c431
467c434
473c440
476c443
479c446
485c452
488c455
491c458
494c461
497c464
500c467
503c470
517,543d483
< <Ambience>
< </Ambience>
553c493
< <Color red="0.34108527131783001" green="0.080644192055765895" blue="0.104965537979071" alpha="1"/>
> <Color red="0.34108527131783" green="0.0806441920557659" blue="0.104965537979071" alpha="1"/>
556c496
< <Color red="0.94186046511627897" green="0.93830927644136197" blue="0.75932936722552702" alpha="1"/>
> <Color red="0.941860465116279" green="0.938309276441362" blue="0.759329367225527" alpha="1"/>
559c499
< <Value value="0.72999999999999998"/>
> <Value value="0.73"/>
565c505
< <Value value="0.69999999999999996"/>
> <Value value="0.7"/>
568c508
< <Value value="0.82999999999999996"/>
> <Value value="0.83"/>
571c511
< <Value value="0.23000000000000001"/>
> <Value value="0.23"/>
574c514
< <Value value="0.64000000000000001"/>
> <Value value="0.64"/>
577c517
< <Value value="0.60999999999999999"/>
> <Value value="0.61"/>
580c520
< <Value value="0.39000000000000001"/>
> <Value value="0.39"/>
583c523
< <Value value="0.23999999999999999"/>
> <Value value="0.24"/>
586c526
589c529
606,632d545
< <Ambience>
< </Ambience>
639c552
< <Color red="0.806201550387597" green="0.71287359142581896" blue="0.59371432005288105" alpha="1"/>
> <Color red="0.806201550387597" green="0.712873591425819" blue="0.593714320052881" alpha="1"/>
642c555
648c561
< <Value value="0.60301499999999997"/>
> <Value value="0.603015"/>
651c564
654c567
< <Value value="0.45789400000000002"/>
> <Value value="0.457894"/>
666c579
< <Value value="0.90000000000000002"/>
> <Value value="0.9"/>
669c582
672c585
675c588
< <Value value="0.28999999999999998"/>
> <Value value="0.29"/>
678c591
< <Value value="0.83999999999999997"/>
> <Value value="0.84"/>
692,718d604
< <Ambience>
< </Ambience>
725c611
< <Color red="0.329457" green="0.24773200000000001" blue="0.28565600000000002" alpha="1"/>
> <Color red="0.329457" green="0.247732" blue="0.285656" alpha="1"/>
728c614
731c617
< <Value value="0.53191699999999997"/>
> <Value value="0.531917"/>
734c620
< <Value value="0.54828699999999997"/>
> <Value value="0.548287"/>
737c623
< <Value value="0.60337099999999999"/>
> <Value value="0.603371"/>
743c629
< <Value value="0.50684600000000002"/>
> <Value value="0.506846"/>
746c632
752c638
< <Value value="0.54000000000000004"/>
> <Value value="0.54"/>
755c641
764c650
781,807d666
< <Ambience>
< </Ambience>
814c673
817c676
823c682
826c685
829c688
835c694
838c697
841c700
< <Value value="0.95999999999999996"/>
> <Value value="0.96"/>
847c706
< <Value value="0.93000000000000005"/>
> <Value value="0.93"/>
850c709
853c712
867,893d725
< <Ambience>
< </Ambience>
900c732
< <Color red="0.51871425298198404" green="0.31468533182990499" blue="0.17901170775407901" alpha="1"/>
> <Color red="0.518714252981984" green="0.314685331829905" blue="0.179011707754079" alpha="1"/>
903c735
< <Color red="0.65894477495342796" green="0.783143200061168" blue="0.93410852713178305" alpha="1"/>
> <Color red="0.658944774953428" green="0.783143200061168" blue="0.934108527131783" alpha="1"/>
909c741
< <Value value="0.45012931360403502"/>
> <Value value="0.450129313604035"/>
915c747
< <Value value="0.42337474805460101"/>
> <Value value="0.423374748054601"/>
918c750
< <Value value="0.65000000000000002"/>
> <Value value="0.65"/>
921c753
< <Value value="0.12746202299718801"/>
> <Value value="0.127462022997188"/>
924c756
< <Value value="0.80997477975207099"/>
> <Value value="0.809974779752071"/>
927c759
< <Value value="0.34999999999999998"/>
> <Value value="0.35"/>
933c765
< <Value value="0.68000000000000005"/>
> <Value value="0.68"/>
936c768
< <Value value="0.26000000000000001"/>
> <Value value="0.26"/>
939c771
< <Value value="0.40000000000000002"/>
> <Value value="0.4"/>
953,979d784
< <Ambience>
< </Ambience>
986c791
< <Color red="0.41085271317829503" green="0.400930444114038" blue="0.28982633255212997" alpha="1"/>
> <Color red="0.410852713178295" green="0.400930444114038" blue="0.28982633255213" alpha="1"/>
989c794
< <Color red="0.82511905631653404" green="0.81052532559735602" blue="0.78420001874905498" alpha="1"/>
> <Color red="0.825119056316534" green="0.810525325597356" blue="0.784200018749055" alpha="1"/>
992c797
< <Value value="0.46000000000000002"/>
> <Value value="0.46"/>
995c800
< <Value value="0.94999999999999996"/>
> <Value value="0.95"/>
998c803
< <Value value="0.51428126241745498"/>
> <Value value="0.514281262417455"/>
1004c809
< <Value value="0.089999999999999997"/>
> <Value value="0.09"/>
1007c812
< <Value value="0.57021913704006899"/>
> <Value value="0.570219137040069"/>
1010c815
< <Value value="0.27000000000000002"/>
> <Value value="0.27"/>
1022c827
< <Value value="0.52000000000000002"/>
> <Value value="0.52"/>
1039,1065d843
< <Ambience>
< </Ambience>
1075c853
< <Color red="0.34496124031007702" green="0.26578324482522497" blue="0.116324139174328" alpha="1"/>
> <Color red="0.344961240310077" green="0.265783244825225" blue="0.116324139174328" alpha="1"/>
1078c856
< <Color red="0.72868217054263595" green="0.72538526451357699" blue="0.55922120064899905" alpha="1"/>
> <Color red="0.728682170542636" green="0.725385264513577" blue="0.559221200648999" alpha="1"/>
1081c859
1084c862
1087c865
1093c871
< <Value value="0.47999999999999998"/>
> <Value value="0.48"/>
1105c883
< <Value value="0.040000000000000001"/>
> <Value value="0.04"/>
1111c889
1119c897
< <Information author="Totte" name-en="aged wooden floor" url="http://www.code66.se/" description-en="A generator for worn, cracked and dirty wooden floors or walls.[br]Wood generator based on the filter Wood by Kochubey," keywords-en="floor, wood, wall, aged, old" update_notes-en="Changed to simple filter as the normal map didnt render at all, and the bumpmap wasn't really needed.[br]Thank sto KGtheway2B for the heads up.[br][br]History:[br]Changed the filter so it now can be placed in the building category." major_version="2" minor_version="5"/>
> <Information author="Totte" name-en="aged wooden floor" url="http://www.code66.se/" description-en="A generator for worn, cracked and dirty wooden floors or walls.[br]Wood generator based on the filter Wood by Kochubey," keywords-en="floor, wood, wall, aged, old" update_notes-en="Changed to simple filter as the normal map didnt render at all, and the bumpmap wasn't really needed.[br]Thank sto KGtheway2B for the heads up.[br][br]History:[br]Changed the filter so it now can be placed in the building category." major_version="1" minor_version="17"/>
[/code]
Totte
Übernerd
Filters: 107
That is weird, but my first suspicion still stands, the download is cached somewhere and whenever you download you end up getting something from that cache, or you have both the old and the new version of FF2 on the machine, and when you download, the wrong version is started and trash it.
it would seem to be something local to your machine, tiger. no one else is having this trouble. it could even be a hardware issue. i've had very screwy things start to happen when a motherboard, harddrive or video card starts to go bad. i dont mean to scare you; maybe all you have is the cache thing, but it could also be something in your anti-malware that's corrupting things or even packet losses or something along those lines. also, if you had a hard crash on your machine you may want to reinstall FF. sometimes programs get corrupted in hard crashes. it doesnt take much, sometimes. one bit in the wrong spot and poof, nothing works right. such is the life on a computer smile:)
tigerAspect
Filters: 9
Freaking FINALLY! I had no idea FF even kept a cache of all the filters you've ever downloaded. So yeah, I emptied out that particular folder, re-downloaded the filters and everything's peachy. smile:D Thanks everyone!
ah, a happy ending. good smile:)
Totte
Übernerd
Filters: 107
Good to hear Tiger!!
My first hunch was correct then smile;-)
